OZYWALKER
Gold Donating Members
    44
  1. Might not fit. I've got the Process West battery tray that sits where the factory air box goes and I had to modify that to fit an optima yellow top. Not sure if you could mod that style of relo kit as it was the length (side to side) that was the problem not the width (front to back)
  2. The v bands that come with it are crap. Had 2 fail already.
  3. Spool billet oil pump gears. Motorsport Connections oil feed line.
  4. Booked ute in for GTX, valve springs and oil pump gears.
  5. There's a setting to do this. Can't remember exactly but pretty sure it's in the manual, something like pressing the volume button in for 8 seconds.
  6. Spent a few hours looking for a missing bolt. None missing from the ute but did find a new one on the water pump in the work van. Then washed it and put a cover on it unit I sort out a GTX.
  7. True. But the turbos farked. Bearings sound shot. So it's parked waiting for GTX money.
  8. Nope, all there. Not from the heat shield either.
  9. Found this bolt next to the ute, where it gets parked. Looks similar to the intake manifold bolts but none are missing. Any ideas?
  10. They said so in an email I got from them a while back, wanted to know if they could get the 8 pot fronts in and they said they can get all the XYZ gear.
  11. Would be interesting to see if performance suspension (Aus XYZ distributor) could do any discounts on a group buy for big brake kits and coilovers.
  12. The wheel deal also has options to view wheels that clear brembos.
  13. Use something like the PW 3 kit. It doesn't need the holes made any bigger.
  14. sh*ty 50hrs from Tues to Fri then get sent to a farked up job all day today (16hrs) and have to stay most of tomorrow.
  15. Avoid scrubbing/rubbing the matte vinyl it can leave shiny patches. Pics!
  16. Lol at user disdocuments9 spamming on AFF
  17. Use a trolly jack under the k frame with a piece of timber on the jack to spread the weight and stop any dents.
  18. Probably meant to prime the turbo with oil beforehand so it's not running dry.
  19. Fixed PW airbox to battery tray with nutserts. No more rattles now.
  20. Or because they cbf designing a new ute rear end since the AU.
  21. Have you gone through the settings in the ICC (interior command centre)? The balance could be set to the drivers side only. The passenger window switch could have worn contacts or just need a clean.
