OZYWALKER
Gold Donating Members
    44
  1. Sweet, I thought they'd go and fark it up.
  2. Going out with a bang. Nicely done.
  3. They're a replacement bleed nipple with a one way valve in them. As long as you use a hose on the nipple no air can get back in. So there's no need to close the nipple until its bled. http://www.speedbleeder.com . Not sure of the exact part numbers but phildo has mentioned it a few times.
  4. Just use the copper ones, sand them flat and anneal them if your worried. Sent from my GT-I9505 using Tapatalk
  5. Better pistons in the F6, and slightly lower comp. Sent from my GT-I9505 using Tapatalk
  6. Twin 76s, you can do it haha
  7. Lol I'm with you stripes. I'm on my 5th vivosmart. Can't complain though rebel had to give me $70 credit with the last one thanks to their system farking up.
  8. Just get the right offset, spacers up front isn't a good idea.
  9. The diff will turn upwards when it tramps. If you don't have any tramp now I wouldn't bother until you get the new motor in. As others have said mals kit is the best in terms of keeping ground clearance.
  10. Easy option is to sell and buy a turbo, will be a lot cheaper to. Motor, gearbox/trans, driveshaft and diff's are different. Not to mention engine looms, sensors etc. Use the search box and you will find a lot of threads with info on this.
  11. If its the same core as the fg cooler I'd be confident its a lower pressure drop than the competitions coolers.
  12. Tig does some great gear. Bov is up to you, vented isn't legal and plumb back is, dual port is best of both worlds and has blanking caps available so legal is possible.
  13. Pulled out the solid engine and trans mounts, fitted genuine mounts. So much better, forgot how quiet these cars are in the cab with factory mounts. Changed all the radiator hoses and swapped back to 98 from ethanol ready for the holiday trip.
  14. There are billet cranks available, standard stroke and destroked.
  15. It will raise the rear end a lot. Front hanger are different to the standard hangers.
