OZYWALKER
Gold Donating Members
    44
  1. CHLAXN's thread, theres a list including the FG 4" http://www.fordforums.com.au/showthread.php?t=11433818&page=4 Not sure about Rednose's thread but I recall it being mentioned on AFF.
  2. It fits as a cat back wich is what CCCC is after. CHLAXN had one fitted to his F6 Rspec and I believe Rednose has one fitted. CHLAXN used an FG manifold and complete Xforce FG system.
  3. Tog is a copy of the Nizpro system. Apparently the xforce FG 4" fits the b series, just not the dump.
  4. That he did. I tried a set of 19s with 335/30 invos would fit with a bit of guard work, but getting a tyre with the same diameter for the front to fit will be an issue.
  5. Might be worth asking if any of them do a setup with more clearance. The racecar engineering setup was pretty average for clearance, scraped on 9/10 speed humps even under 5ks until I cut the front brackets for more clearance.
  6. Looks like they are a custom job to give decent clearance. Same setup just redesigned for more ground clearance, should be how they all are for the falcon utes IMHO.
  7. Not sure but they're heaps better clearance wise than the caltracs from racecar engineering. Looks like they'd work fairly well. That silver utes tray looks pretty good to, gotta get me one.
  8. Sure did, heaps better than the leaf setup. There's the Performamce Suspension kit, wich isn't cheap ($4300) but it's all bolt in. It does need exhaust mods. Or McDonald Bros racing make a weld in kit ($2500) but you have to remove the fuel tank as the links run between the chassis rails. Just work out what height you want to go with before ordering a kit as they're usually pretty low.
  9. Not to bad that ay fella. Considering I got a $25k toyota sh*tlux.
  10. Cooper's sparkling 11 down, good luck 4am start tomorrow.
  11. You'll need new olives for the fittings and hose to extend the lines. Cable should be fine, can't see it pulling more than 10A. BOV position is good, the closer to the throttle body the better.
  12. Do you even diff bush? Get the independent Motorsports kit, you'll find a shop that will fit it.
  13. Trailer park boys season 10 is up.
  14. Yes but I removed the lower "helper leafs" and the saddle bushes so it was probably 20mm lower than standard height.
  15. Still 295s. Needs 335s or 345s on 19x13, you can do it camo.
  16. She'll be right, new shock and a wax then it's happy days. Really interested to see how it all goes, see if I've wanted money on the rear end or not.
  17. Looking at those leafs there's a fair bit more on them than the standard ones. It's probably going to help a fair bit with tramp. Gonna sit sweet once they go in.
  18. That's sucks man. Dodgy charger or battery?
  19. ^^^ lol Farkin carnts the queue across intersections in peak hour. Makes me want to sell my ute and get a patrol with a 5 post bullbar to ram the pricks.
  20. I'd be going to fair trading if he doesn't come up with the box soon. Over a years wait is farked.
