OZYWALKER
Gold Donating Members
    44
  1. Sounds like a similar design to nizpro's system. Pretty sure hurricane is a Liverpool exhaust brand.
  2. He's right they look crap and they'd fark with the spread/throw of light. Best bet would be to hassle the club fg Facebook group.
  3. Also why not roll the front? You can get a fair bit without the paint even looking like cracking.
  4. At least go 18x9 front and 18x11 rear. Will not need rolling if you get the right offsets. You know you want 300+ wide tyres up back.
  5. Should be fine if its a stocker. The throttle progression is pretty idiot proof.
  6. Genuine ford
  7. The fuel tank being on that side probably adds to it.
  8. You said it Jet. If you can't get the mythical F6 registered k31th I'm sure there's be plenty of forum members more than happy to help you with a motor and drive line swap. You know you want to haha
  9. I agree with Arron on that one. My ute has always kicked out towards the lower side of road regardless of suspension setup and I've tried a fair few setups.
  10. They can bend a bit, I found the aftermarket braided lines have a bit more give in them.
  11. Depends on the width of the tray. The fg at work has a b series bocar tray on it and it looks the same as any other fg tray back. As long as its wider than the rear wheel track it will look fine.
  12. Sure can. Chassis behind the cab is the same. Wiring for the tail lights may be slightly different.
  13. Fronts will clear fine, may need to roll the guards depending on how low the car is. Rears are a different story, need measurements of the tray and chassis from a wheel with a known offset.
  14. They tray will be the killer. I tried my old 18x9.75 rears with 295s on the work ute for lols (fg tray back) and the poked a good 30mm past the tray but tucked easy on my ute with the tub.
  15. K31th wins haha.
  16. Ordered some pink bits for the ute. Xtreme 230mm twin plate ceramic clutch kit. Probably the best bang for your clutch that holds decent power. Will see how it goes.
  17. But what if tapafark is doing this sh*t as well, then how are you supposed to know. Broke login is broke.
  18. Small turbos run hotter freaky, falcons overheat easy at the track.
  19. Why bother it would be a pig without the turbo. Get an NA like a normal p plater.
  20. Gotta get me one of them.
  21. Ferodos are real good freaky, fairly dusty. You'd run DS2500 up front and DS Performamce rears. You really gotta go brembos man, miles ahead of the stockers.
  22. Found that the nulon stuff just makes it a bit quieter for a 1000ks or so, no difference besides that.
  23. Got the guards rolled and pumped a bit, wheels fit now.
  24. k3333331111111th, sup mang. The more episodes of Fargo they make the weirder it gets.
