OZYWALKER
Gold Donating Members
    44
  1. How good do those S1Sequential shifters look for the tr6060. Anyone gonna be the guinea pig?
  2. Ordered a short shifter kit from core shifters. Will probably get here before my ute runs cos manual conversion ecu dramas.
  3. Will drive to yours if you make me a bitchin tray for my ute, needs side pipes and all to go with it haha. Not donating my ute though.
  4. Yea but no but yea. Can't help with that cos I'm sure the ladder bars on my ute are lower than that.
  5. Probably the center bearing
  6. Hey trana, superpro have offset arms which can allow up to 315 wide going by their site.
  7. Sounds exactly like the nizpoo exhaust hahahahaahhaahahahaha
  8. Aftermarket manifold makes a fair difference too. Dunno lol, my ute sorta sounds like a 2jz when it dumps before the mufflers.
  9. K31th, haven't you heard a barra without an exhaust? Tractor spec tone with a dump only. The cat makes it deeper and takes the harshness out of it, mufflers help a bit too.
  10. Common problem chances are they weren't changed, a visual inspection will give a rough idea of age. Use the search function next time there's only a sh*t ton of threads asking the same thing. Use genuine coils only, the cheapest correctly gapped plugs are the ford LPG ones. Modded waste gate means its tuned or its Habib spec modified.
  11. On the money there Ralph haha. You'd think if it want getting spark you'd check the ignition coils and plugs hey?
  12. Worn out coil packs will cause the speedo and bogging down problem.
  13. The Shockworks coilovers are very soft for a coilover setup. Just seem like a highly refined ride with similar to standard sprig rates. I ended up fitting stiffer coils to mine as I found them way to soft.
  14. Coil overs all round. Doesn't end up being too much more than new coils and decent new shocks.
  15. Surely if you can do a clutch in your driveway you can get the zorst done. Or are sedans that chit compared to utes?
  16. Wolf Of The Willows - Johnny Smoke Porter. Didn't know you could get that much smoke into beer. Interesting brew.
  17. Same here, will let you know how the pzero corsas go. Guessing the same as the invos for mileage.
  18. As much as they are copies a lot of the "copied wheels" are made to jap wheel standards so are of very good quality but are a lot more affordable than the big names. I've found that most of the copies eg Rota are made to high standards but usually have a lower weight rating than the originals.
  19. Dude super crunchy ain't got nothing on the crunchy american peanut butter from aldi. Top stuff that is.
  20. Just get one of the mobile guard rolling guys to come out. Sydney guard rolling has a good rep. I used outwest creations, he did a good job. Fronts are no probs but if you want to do the rear you'll have to remove the spot welded brace to allow the lip to be rolled. Then you'll have to make a new brace or modify the stock one to stop the quarters flexing out when hitting bumps in the road.
