benjam
1 Neutral
About benjam
  • Birthday 16/07/1971
Contact Methods
  • Website URL
    http://www.benjam.com/mycars
  • ICQ
    0
    Sydney NSW
  1. Happy Birthday benjam!
  2. Happy Birthday benjam!
  3. Happy Birthday benjam!
  4. Happy Birthday prae!
  5. Happy Birthday Gr3chie!
  6. Happy Birthday kcjazzra!
  7. Happy Birthday outbakoz!
  8. Happy Birthday xr6magnet!
  9. Happy Birthday fg turbo ute!
  10. Happy Birthday Infamous!
  11. Happy Birthday st3lthxr6t!
  12. Happy Birthday benjam!
  13. benjam
    No Boost
    Yep currently having the same problem, though at first it would make some boost, slowly up to 6psi at max rpm. Car is tuned to 12psi with standard actuator. I checked manifold bolts, all hoses and clamps and even replaced the wastegate control solenoid. Then by coincidence the dump pipe to turbo bolts came loose so tightened them. Now no boost at all. I had my local Ford service take a look because I spotted a turbo housing bolt loose on the exhaust side, which I couldn't get to. They tightend that and also found a turbo mounting bolt missing. But still no boost, so they took the dump pipe off and found the wastegate stuck open. Will be taking somewhere else to fix that as all they could offer is send the turbo away for a rebuild. So a few issues all at once, but main one is the wastegate stuck open for me. Cheers. Ben
  14. Depends what you want to do with your car. Under half a tank doing circuit racing you'd be running the risk of fuel starvation, which can lean out your air fuel ratio briefly and lead to detonation. Even more serious drag racing or spirited twisty driving around 1/4 of a tank could cause probs. Inside the fuel tank, the fuel gets pushed to one side, away from the pickup due to the G forces. For me I have one just for track days as otherwise I don't push my car hard enough to worry. It means I don't have to refuel after only a couple of ciruit runs. After experiencing the difference I can say it definitely works a treat. Cheers. Ben
  15. Here you go, some info I saved a while ago before I bought one myself. Cheers. "The correct T-Piece to use is a VDO 230.032. The standard thread in the oil sender is 1/4 NPT. (the autometer is 1/8 NPT)." The above t-piece will make it look the opposite of the pic Dwayne posted, ie Autometer sender on top (1/8 fitting) and original on the end (1/4 fitting). Ben
