fpv229
2 Neutral
  1. whats the oil pump do and what aftermarket ones would u go..also what price range are they as im abit strapped for cash atm. and yeah the cams honestly are for the sound mostly lol
  2. what cams did u use mate?
  3. cheers, so you guys would recommend cams. what brand have you gone for as im looking around and also whats the price range where looking at?
  4. well I have pretty much done all bolt on upgrades apart from turbo upgrade
  5. well I am ordering a new bottom end on monday so there goes the idea of forged pistons, etc. just more wanting to know what sort of upgrade are worth in the top end and if its even worth touching it? I.e port and polishing the heads, valves, valve springs, cams?? if anyone has any info would be great
  6. blew a piston in my 6th cylinder, buying a new bottom end motor, and getting the top end rebuilt. wanting more power out of the car, so whilst its all apart just need few ideas of performance mods I can do. e.g cams, pistons, etc
  7. yeh can u put up a pic mate? im running SSL rear and SL fronts but its still too high lol
  8. hey mate what spring height u running in this pic??
  9. what springs are they mate (SL, SSL??)..im looking to probabaly go abit lower.
  10. iv got the tools and yes basic mechanical minded always willing to learn so if its not too bad then id spend a good day doing it that's not the problem. I take my car to bluepower in campbellfield im from melb, they do a good job there and are willing to do it all just low on the $$ atm so thought id save myself the labour.. so basically all they will do is bore out the internal wastegate, install 12 pound actuator and install a bigger flapper??
  11. looking to lower my bf mk2 rspec, most likely with king springs...just wanting to see pictures so I can roughly see what it will look like. cheers
  12. so I guess ill prob just stick with internal..also to save some $$ on labour is it an easy job to remove the turbo or wouldnt recommend?
  13. thanks mate so far I have done 60lb injectors, high flow cat, plazaman 800hp cooler, air intake and battery relocation and im 340rwkw..im just looking now to get more power and the next mods I need are a surge tank with fuel pump and full exhaust, plus the turbo mods (actuator)... im just stuck with turbo mods as I dont know too much about internal and external gates and ive heard they bore out the turbo so im abit confused here. ive done a fair bit of research it just wont click lol. any suggestions turbo wise? I love the sound of external gates and I heard they are better for more power as eventually in the long run I do want to be running quite abit of power.
  14. ?????
  15. hey there abit confused with what mods I need done on the turbo? I understand it has an internal wastegate, what needs to be done to get an external wastegate done? does the turbo need to be bored out for an exhaust? and the actuator whats the go with all 3 im abit confused atm.. looking at a 4inch dump to a 3inch system x force and love the sound of external gate? please open to suggestions and help!
