AdamIan69
Bronze Donating Members
41 Excellent
About AdamIan69
  • Birthday 18/11/1987
    WA
  • Interests
    Cars.... and making money.
1,890 profile views
  1. Happy Birthday AdamIan69!
  2. Happy Birthday AdamIan69!
  3. Centrifugal blown xr6 with a high stall against a std Fg f6. I would put money on the blown xr6. And very good observation sexual harassment, good to see you've read the owners manual.
  4. The turbo conversion is pretty common but it will cost you more in the long run. A motor may cost you 4k but then you got exhaust, map sensor, air box and tubing, gear box, intercooler and piping, plus tuning.
  5. If you need help doing the service look over this site and you'll find all the info. I also have the BA workshop manual on CD. But it covers the ZF 6 speed auto. And allot of the sh*t is the same between BA and Fg. Except wiring diagrams,
  6. A cracked head will leak when hot, but will sometimes not leak when cold.
  7. I had 4.11:1 in my gt and it was awesome but fuel consumption on petrol was a killer.
  8. I would say about the same time, although with the power your running you will have to pull the box in the future to tighten a loose flex plate, due to ford not loctiting it's mounting bolts. <br /><br />I recall a high stall will set you back about 1200-1500, and that is machining your old one. But call CMS or your local tuner for pricing.<br /><br />Do XR6's come with lsd's? If not then you will want a try trac in the future aswell. So you could end up doing both jobs.<br /><br />The high stall will also put more load on your driveshaft, where diff gears won't affect driveshaft load at WOT and anything under WOT there will be less driveshaft torsional stress. <br /><br />Depending on the size of your wallet, will depend on what gears you want, I would go the high stall to keep fuel consumption around normal. And 3.7:1 if your wallet is a little thicker, 3.9 if you like getting 400km per tank of fuel while cruising and like frying tyres almost instantly on take off
  9. The standard driveshafts are stronger then the turbo driveshafts, diff gears will increase your fuel economy as the engine is reving higher all the time. A high stall will allow the engine to rev higher when the car first accelerates which will get you on boost faster.
  10. Jack up the RHS of the car just enough to get your head under, and pull the filler plug out the RHS bottom rear of the box " with the engine idling in neutral" and put some more GW Syntrans in until it trickles out the side. Then lower the car while it is still idling and wait for the trickle of oil to almost stop. Jack the car back up, replace the plug and do it up "gently". Then turn the car off and lowering it to the ground. <br /><br />Do it on level ground ofcourse and you will need Allen keys about 10mm or 3/8 by memory and a oil syringe with a hose from repco. Also a container that will fit under the auto box with the car lowered to the ground.<br /> Do that before you worry yourself to much. There is plenty of time to worry later lol.
  11. You checked the oil level lately?
  12. 100km service. Expect about $450 genuine ford ZF oil for the auto, $200 for synthetic engine oil and filter, and $150 for synthetic LS oil, $70 for brake fluid flush, $100 for coolant flush 70 for power steering. <br /><br />I have never had it done before but expect those prices IMO.
