bloodycrashboy
Bronze Donating Members
    88
Everything posted by bloodycrashboy
  1. just one of many
  2. mine wasn't so big not as small as your NUC though
  3. Cosmos 30mls of vodka, 15mls of Cointreau, 30mls of fresh lime juice, 90mls of cranberry juice over ice [emoji106]
  4. Wow, that's one behemoth of a graphics card [emoji50]
  5. I'm now an AMD fan boy took the fan off to mod it to fit inside the case turned it over and spied a small screw undid it and hey presto the top part of the fan shroud un-clips from the bottom fan now fits in the case did some cable cramming now all done and dusted
  6. cable management in a mini-ITX case the struggle is real
  7. Mini-ITX literally fits in the palm of your hand (sort of) re-used Mrs BCB's old SSD the fan protrudes a fraction 2 much I'll have to take that top shroud off the fan and do a few mods the side panel does have a dish but it misses by a couple of mm fired it up and the hardware recognized the old drive and booted straight to it haven't even gone into the BIOS yet to setup anything! Cat is totally unimpressed
  8. got Mrs BCB's parts today hope it goes together ok the CPU fan /heatsink is always a worry using a mini-ITX case so not to appear as a hypocrite, I'll post a couple of build pics tonight
  9. where are the pics??????
  10. looks like a direct hit for the BCB household we are about a third of the way between Cairns and Port no biggie really as long as it doesn't intensify too much more might get a day off work tomorrow though
  11. @k31th has broken the forum .........again
  12. I had 2 8Gb sticks got another 2 to fill the vacant slots with RGB, cos need more RGB didn't notice any discernable difference with 4 sticks vs 2 sticks or even 16Gb vs 32Gb my RAM is G.Skill TridentZ neo. 4 x 8Gb DDR4-3200 CL16 which was recommended as the sweet spot and bang for buck for the AM4 Ryzen 3000 series way back when you are very welcome I have also download AMD Ryzen Master Utility and adjusted the fabric clock and the memory clock to the same values you can download it HERE in my case it is 1600 on both (adding together to make 3200 as per my RAM speed) also have the Ryzen power plan for windoze all info HERE I have been running this software for over 12 months without any hiccups My CPU is set to run on max boost clock all the time and does so without any dramas (cos on water) I hope to see some pictures from both you and @Rab of your builds a time lapse video would be great
  13. looks like you are right on the money with that kit did a bit of searching and had a read of THIS article to cut to the chase .....
  14. its in the 3 dots on the right hand side of the post whereas the "quote" tab is there to see in all its naked glory see, edited
  15. lol I'm always editing my posts cos always making mistakes ok, found the "edit" tab
  16. what happened to the "edit" tab @k31th?? all I have is the "quote" tab cant edit wot. cant talk cos busy putting all my single posts into one?
  17. did a lot of research before I built my Ryzen system 15 months ago 3200Mhz was considered the "sweet spot" and if you look at recommendations from AMD, 3200Mhz is the number they use eg: @Rab has a gen 4 Ryzen gen 5 by numbering 4 must have been an unlucky number for them or something
  18. no drama there mate
  19. my limo is the same colour and the sun does bring out the "bling" in the duco Purple's, greens, pinks, blue's and Reds [emoji106] in the sun
  20. Awesome stuff @Rab [emoji106] Need pictures of the build [emoji846] Edit: I just bought a Gigabyte Aorus X570 mobo for Mrs BCB's new build Mini ITX but [emoji106]
  21. your massive quads and calves
  22. Well I'm VERY happy with your efforts Keefy the one thing that has been pissing me off about this forum since the last upgrade is now fixed I am no longer taken to the "new members thread" every time I try to navigate somewhere for you PS: love the wider format
  23. Mrs BCB was given a set of 5 Essteele stainless steel/copper based pots for her 21st they are still rocking today, 30 something years later
