chilly2607
  1. Will a fg xr6 diff fit ???
  2. I have a bf mk 2 xr6 t with a blown diff cradle is cactus and control arms will the fg gear fit ??
  3. Hi All I Heard a noise coming from the diff last night in my Bf Mk2 XR6t so I put it over the pit and had a look and reliesed the diff bush was broken I then drove it home around 2 ks away and while I was turning a corner BOOM !!! oil and C**p every where I just want to know of any recomended upgraded diff ect I should be looking at Cheers
  4. na I dont have a boost gauge a few people have said the same thing either over boosting or the valve could be blocked on the breather hose thanks for your reply
  5. Hi I have a bf mk II xr6 turbo and I am having a couple problems I have recently replaced all my turbo joiners with the silicone 1s as the standard 1s where perished and I was loosing boost from the throttle body but since I have done that the vacuum hose that is on the rocker cover leading to the throtle body keeps blowing off when I give it some curry is this from the crank case preasure being to hi ?? Hopefully not :( also the little dust cap on the throttle body keeps blowing off aswell the car has been tuned for 12 psi had a high flow cat and walbro fuel pump and intercooler it was 287 kw when it was last tuned Cheers
