MITCH-JOSH
  1. Was a cold morning about 5:20 am
  2. update: took car for a drive yesterday because it was annoying me just sitting their, still overboosting but engine light didnt come on or go into limp mode, did a few wot's and still fine, will get a full service and scan done this weekend and hopefully all will be fine
  3. No I haven't changed the plugs as of late, ill get a scan run over it too see what fault it throws up and an I guess ill go from their. Thanks for your help guys and ill let you know how it goes.
  4. It lasts for about a second before the auto box changes gear upon wot, I'm unsure of what the exact rpm is but it's definitely not hitting the rev limiter lol
  5. Hi guys, I have a November 03 build auto xr6t with 170000 Klms, completely stock other than 20" wheels, as of late it has started to what I believe is overboost, feels like I'm hitting rev limiter and loss of power but it's no where near limiter, also as on Friday I experienced the engine light come on and it went into limp mode and upon stopping the whole car was shaking like as if the engine was labouring up, turned the car off and it started back up fine and I parked it and haven't touched it since then, I have done a little research about the what I believe is overboosting and every thread their hasn't been a definite answer wether it was plug gap or the wastegate actuator, coil packs or a fuel issue, I'm going to get ford to run a scan to see what the fault was/is but just am seeing if anyone else has experienced this and has an answer or for where I should look before I get a mechanic to touch it, thanks for your time
