lewie
  1. Ok add pipes and better flowing cat the list I guess. What's the cheapest pipe kit you guys have come across?
  2. First pipe as in the first section of pipe which bolts to the turbo outlet. Is this the piece that fails or have you heard of other pieces failing.
  3. Is it always the first pipe that fails?
  4. I/C probly wont be needed at the power level im after and also the fact I never constantly flog my ute or hold it at max boost for long. Probly would only have tuned to 12-13psi with the above injectors. Im thinking the pipework will be fine for the low power im chasing and also the way I treat my ute.
  5. Hi all I have just bought a 2011 XR6T ute in edge, has only done 20,000ks and is un modified apart from me puting in better stereo and soundproofing. I want to keep this ute quite standard to the eye and not go silly spending big money on it. I dont want big power because I want driveline etc to last and if I went silly id probly crash the thing haha. Plans are for 1" blocks in the rear to level it, $90 instead of $400 for leaves reset. And on the motor side of things I was thinking: Herrod airbox center or rear muffler removed turbo intake muffler changed to plain alloy or stainless pipe (may not even bother with this) 42lb injectors X3 and somewhere to have tune done I dont want to replace standard I/C or I/C pipework. What power would I be looking at with the above mods? Id like to make just under 300 I guess. Its always got 98 in it too Any thoughts or ideas on this would be helpfull, thanks Lewie
  6. ive heard that lowering the back only will slightly raise the front, what are your thoughts?? What would postage to brisbane be Pat? thanks
  7. I have just bought a 2011 xr6t ute with 20000ks, front height hub to guard is average 368 and rear is average 399. Seems low enough in the front for looks and practicality of not scrapping the crap out of the front bar but I would like to lower the rear with king springs to level it out as I dont carry much weight only a dirtbike every now and then. Was thinking FOR-303 or FOR303SL, anyone had these in their ute? and where is a good place to buy these at a good price? thanks in advance lewie
