For durability I wouldn't be tuning the WOT fuelling to be much leaner than mid 11's. I'd pick the actual AFR number based on exhaust temperature, as this is a major factor in what determines the durability of the turbo and other engine components, eg exhaust valves. You may be able to get more power running leaner to 12.6 but only if you could put the spark into it. The pre-turbine exhaust temperature would probably be very high too, perhaps over 1000°C. This would certainly reduce the life of the turbine bearing carrier! As I mentioned previously, if you run it a bit richer you may be able to gain more that you lost by being able to increase the ignition advance. Advancing the spark towards MBT also has the advantage of reducing your exhaust temperatures because more of the energy is being put into the piston and less is being put into the exhaust. On a bit of an aside and an example of spark advance and its influence on exhaust energy, I spoke to the guys from ION a couple of years ago, when they were supplying their 4 speed transmission to Maseratti (3200GT I think). As is typical of most modern cars, their transmission controller was calling for a reduction in torque on gear shifts, which is done through ignition retarding. However because of the spark retard, and the consequential increase in exhaust energy, boost was going through the roof on gear changes. The engine wasn't producing any more torque, just boost. In the end they had to make some software changes to control the boost on gear shifts otherwise they got too much wheel spin when the shift was over and they let the engine have its spark back. The car manufacturers pick the fuelling pretty much by the exhaust temperature (though power has an influence) as they have the responsibility to ensure that the engine and the exhaust catalytic converter last for the life of the car (emissions components are required to last over 80,000 km and still meet the emissions requirements, Euro 2 or Euro 3 depending of if you have a BA or BF respectively). It's temperature that degrades catalysts, and if you go above about 950°C in the catalyst it starts to degrade very quickly. If it is starting to look like WOT fuelling and spark is a bit of a juggling act, well it is. However if you've got a dyno getting the peak power isn't too difficult.
