I've had a bit of a look too on my BA II F6, but not had any luck in pin pointing the required connectors. After removing the double width plug (16 pin, female) that's connected to the ignition barrel, I am not certain which plugs need to be placed back in the socket. Is the the one which connects to the start button or is the button still required to be connected or does it tie into the ignition barrel wiring? I only ask as the female end of the starter button is cable tied and hence won't reach. I do know the instructions say that a the male end should go into the barrel wiring, but I am not sure if that's correct as the plug that released for me is The There's also one other single width plug that connects to an unknown plug (to me at least) that appears to be associated with the ignition wiring and it fits into the barrel plug if you place it half way... One thing of note here though is that if I place the single width (8 pin) plug into the barrel wiring, the dash does not light up and obviously no ignition occurs... Finally, there is another 8 pin female connector up near the back of the barrel, but it is in the harness, so I would need to cut the harness to run it down to the plug... Perhaps I'll take some pics this afternoon and upload them. Hopefully that at least makes some sense though in the meantime... EDIT - fixed some baaaad writing, not sure if it's much better to be honest
