sinkas
  1. Hi Fat-Tony, Have you had a whiteline springs fall out in an awkward driving situation? Cheers Case
  2. Hi All, Any of the dealers listed at : http://www.whiteline.com.au/dealers_au.htm have good knowledge on set up of Whiteline stuff. Cheers Case
  3. Hi all, Replacing OEM shocks with performance ones is "best -practice" when fitting uprated springs. In the short term the OEM ones will probably doa decent job, but thees extra workload they are put under by the stiffer, and lower springs will see them wear out faster. It all probably depends on how long you are plannig on keeping the car. Cheers Case
  4. HI all, Do you guys realise that Whiteline also have fully adjustable coil over kits available for the BA? Cheers Case
