brycieboy
About brycieboy
  • Birthday 14/11/1987
    carrum downs
  1. Happy Birthday brycieboy!
  2. Happy Birthday brycieboy!
  3. Happy Birthday brycieboy!
  4. I got my enkei SC38's from greg @ http://www.gstyres.com.au/
  5. kinda.... the aeroforce gauges needed a few wraps with some tape to make them fit snug. the autometer gauge needed the holder modded to fit. (though its a mechanical boost gauge. mounting bolts had to be cut down, hooles for them had to be made bigger in the cup, the base plate had to be modded as the fittings hit. also fairly easy to fit. I was a little concerned when the instructions said to use a screwdriver or butter knife though.... just dont loose the yellow clips into the dash.
  6. ss inductions holder
  7. I run a 19x9.5 +35 on the rear of my ute with a 295
  8. most sandwich plates come with blanking plugs for the holes. on another note.... I have just installed my gauges in my FG... unfortunately I didnt read any threads prior. I had notice most people go with the autometer cobalt gauges so I went out and purchased a mechanical boost gauge. upon leaving the shop I tried to slide it into the cup and it had no sign of fitting. so I went back to return it and the guy assured me it would fit.... after getting it home I had to drill the holed for the bolts out slightly as they were out. then it was able to slide the gauge in. after cutting them off I found that the power terminals would not fit either, so they were bent down and trimmed and power wires soldered on. then I realised that I had no chance of fitting the bulky fittings for the boost line in... out came the die grinder and the base got modded.. all good now! I used the grommet in the passenger side footwell (it comes out near the manifold. and I got my power from the spare light plug for the cigirette lighter ( (on the loom just near the cigi plugs) the other 2 gauges are aeroforce.. much easier to install. (plug into obd) this shows the bit that had to be die grinded. its not to noticable. )I will put some black tape over it to hide it oneday
  9. brycieboy
    ute register
    my manual 2010 FG XR6T ute, only had it a few months and is just about to hit 20,000km. I also have a VU SS ute. have done a few mods to the fg. intake muffler delete, vinyl wrapped roof and dash spears, splashed some plasti dip around to and starting turning the cream trim black, aeroforce and a autometer boost gauge, white led footwell and roof lights and some more.. lots of plans in my he
