bandblightfoot
Everything posted by bandblightfoot
  1. Built 4 inch battery side intake for my fg now off to the powder coaters and hopefully fit it all next weekend.
  2. There is a seller on ebay selling complete bolt in unit 1tufxd I got mine for $35 don't know if it's a rip off but it was easy to install and looks awesome
  3. Pw has 6 inch to 4 inch bellmouth to take a 6 inch filter still a 4 inch intake. Plaz has 4 inch filter on 4 inch pipe.
  4. Just purchased components to make my own will post pics when I have completed probably next Sunday cost 145 so far for silicone reducer 45 degree mandrel bend 4 inch pipe and filter.
  5. Don't do lowering blocks do it right you 2nd have all sorts of issues down the track
  6. $2500 for flash tune injectors and venom cat at most tuners. Good intercooler kit like process west $1600 should see you max out the baby turbo around 300 to 320rwkw.
  7. Lowered pedders suspension tramp rods fitted and full detail now time to test it out.
  8. Fitted malwood tramp rod kit and lowered leaf springs no more annoying creaks and strange noises on take off that was so annoying.
  9. I used sandwich plate and ran oil temp and pressure as mine had 2 outlets.
  10. Quite easy to install yourself you shouldn't lose much fluid just pre fill the pwr unit before final fitting.
  11. If you are not going to upgrade your turbo the factory intake will be fine just drill some extra holes in the bottom. I had muffler delete and it is very loud in the cab you can definitely hear it. My mate has turbo side intake and it sounds awesome all comes down to personal preference.
  12. I ran the pwr unit because I was told the zf gearbox needed the coolant to heat the oil and keep it at the correct operating temperature. Don't know how true but it looks good installed.
  13. Just a query have heard mixed reviews about split dump pipes are they any good
  14. Pwr do a bolt in kit can do it yourself or any good mechanic.
  15. Don't know if it helps but process west piping kit bolts directly up to standard and f6 cooler as I did it in mine before putting in bigger cooler as plastic pipes were cracking.
  16. It already has one just replace it with a compact turbosmart if you want to vent to atmosphere direct replacement 5min job
  17. Can you drive with the intercooler kit without getting a tune
  18. Just installed pw stage 2 intercooler and piping kit. Just trying to find time to get it tuned if I take it easy driving is the car going to be fine for a week.
  19. Got pwr cooler installed and flush at same time at 80000km. Refilled with gw have had no issues and been going strong for 6 months.
  20. Need for speed rivals is a prerty good racing game for the ps4
  21. Earls in line puts the filter at the front of the rocker cover for easy maintenence one of the first mods I did after hearing some horror stories.. about turbos starved of oil.
  22. Earls in line puts the filter at the front of the rocker cover for easy maintenence one of the first mods I did after hearing some horror stories.. about turbos starved of oil.
  23. Venom bolt in cat 1000cc injectors and a tune was $2500 before chrissy from elite and hi-torque and a good cooler and piping $1500-2000 and you will max out the baby turbo somewhere just north of 300rwkw and massive gain in torque.
  24. Im about to start modding mine the stock turbo wont let you get more than 320rwkw that's what elite have told me.
  25. Guages finally arrived from the states through amazon heaps cheaper than local.
