Everything posted by ledoff
I have the same beep in my xr6 t, I can't turn it off in the icc. it has the option to beep the horn when locked/unlocked and they are both off. any ideas?
Fg Cheapest Way To Make 300Rwkw? Uni Student Budget
ledoff replied to sct911's topic in General Tech
for what it's worth, with my old car it always ran better on caltex 98 compared to bp 98 an this was in a relatively high comp n/a motor, although im sydney and it may be different to the rest of australia.- 190 replies
- 1
- fg xr6 turbo mods cheapest
- fg
(and 3 more)
Tagged with:
are you using 98?- 190 replies
- fg
(and 3 more)
Tagged with:
put you car in a high gear and drive up a hill so it is under load, and if it sounds like a diesel it will most likely be pinging- 190 replies
- fg
(and 3 more)
Tagged with:
I thought I would just share how well my car turned out after a wax. the wax I used is dodo juice banana wax, it's a bit exy but it is so easy to put on and take off, and water beads nicely on it. well here are the photo's it beads quite well, it will be alot better once I do another coat. IMG_0198.MOV
[MAQWET] if you can get one that goes with the traditional format I.e AA00AA it is a lot cheaper than a full custom plate.
say you had a ecu out of a wreck with a tune on it and ran that everyday, and just put the original back on for warranty claims, would that work?
sweet thanks for the quick reply, ill give that a go tomorrow. much appreciated. Jack
When I first start the car it gurgles, like air is trapped in the cooling system. it stops after a bit of driving. has any one had this before? I did some research and apparently it is common for air to get caught in the heater core, so my plan is to cycle the heater on and off over a couple of drives, would this fix it? cheers edit: car doesn't over heat or heat up unusually quick and has more than enough in the coolant bottle.
keen to test mine out tomorrow, previous owner got 3.6 with crappy tyers on the strip with 396 rwkw
save up and do it all at the same time, it will be cheaper in the long run. just spend the extra couple of hundred and do it all at once.
nice car man, hopefully I can get around the same power when I go e85
Just Got A 400Rwkw Fg Xr6T, Need Some Questions Answered
ledoff replied to ledoff's topic in General Tech
yeah, I will as there is a united close to home, I'll drive it as it is for a while until I get some funds together and so I can also sort out some bigger wheels before I start making more power :O -
Thanks for sorting the post restriction thing out! -
haha yeah I was stoked with the price, it has 67XXX. on another note how to do I get more post per day? this is my last one. -
25k -
yeah very happy, the hardest part is going to be not destroying the tyres lol -
so the full list of mods are as follows: engine -102mm exhaust with flapper valve -high flow nizpro injectors -nizpro overboost valve -nizpro intercooler and pipes etc -nizpro flex plate -35/40 turbo .70 compcover and modified wastegate -nizpro valve springs and shims gearbox - stage 2 nizpro -bllet input shaft -extra clutch plates in all gears including new linings and steels brakes suspension -6pot front brembos, stock rear -bilstein struts -adjustable rear camber arms -
<blockquote class='ipsBlockquote'data-author="f6mark" data-cid="1343643" data-time="1357118279"><p> what turbo u runing mate.?? GT35/40 or GTX35/82r mate.??</p></blockquote> yeah it's a gt35/40, I wil post up full specs tommorow if any one is interested -
Yeah nizpro pipes as far as I can tell everything in the intake, turbo and injects are aftermarket -
yeah he did, he new he was going to blow it running that much power, it lasted around 40 thousand km until it died. the box was done 6 weeks ago... -
im fairly sure its around 18psi as the, I know the nizpro overboost valve is set to 19 -
