sly40t
2 Neutral
645 profile views
  1. thank you
  2. hi eveybody I have fg xr6 turbo I blew up the transmison I am putting a second hand one in do I have to change the megatronic and if I do how hard is it to do
  3. thanks for your help
  4. didn't want to fix it ? before I go spending money just want make shore that's the problem
  5. cv performace
  6. Hi every one I have a FG xr6 turbo with 1000cc injector e 85 fuel pump intercooler and custom tune .took the car to the tune shop great tune but cold start took it back they fixed cold start the no boost at 80 km when jump on it took it back from 370 rwkw to 350rwkw they re tuned it and told me my cam gear are gone it not taking timing anyone had this problem .can any one share any light on this also plugs are gaped at .65 will that cause any problem with the timing problem
  7. your funny
  8. what did your mechanic think
  9. have checked oil level and is ok
  10. thanks
  11. Hi I have a 2011 FG xr6 turbo with a few mods making 322rw/kw 2 day ago I gave it a hit of the light and low oil pressure come on the cluster and motor noisy could it be the oil pump.????????
  12. turbo bolts going loose
  13. give a day or two get picture and all details will get back to you
  14. thank you all for your support and responses pulled apart today results were timing chain ok . number 3 and 5 cylinder bent valves . cylinder 3 no comp . and 5 low comp
  15. Hi everyone I have a FGxr6 turbo . mods cooler. full exhaust. 1000cc bosh injectors.e85 fuel pump. and eternal gate and screamer pipe . and safe tune . last week leaving work jumped on it wheel spun up the street. then I heard a rattle sound turned the car off checked under the bonnet and found the harmonic balancer broken and key way missing. tried to start it and sound like its got no comp. bottom end turning but not top end due to key way missing does anyone think I have bent valves . I am a mechanic never seen something like this
