bupalooga
Silver Donating Members
    6
bupalooga last won the day on May 10
bupalooga had the most liked content!
139 Excellent
About bupalooga
    Griffith NSW
  • Interests
    sssssstustustustuuu!
7,968 profile views
  1. Pic uploads work now @STAINLESS again plz . Anyway, I watched some YouTube vids, learned Autocad & bought a tig off marketplace. Still have front infill pannels, rear taillight pannel & drop sides to do, but they'll be a while down the road since we're about to settle on a house. Is about 300kg lighter than the steel tray I had, much more aerodynamic, economy & wind noise are well improved. Sent from my SM-S911B using Tapatalk
  2. Sounds like a very similar setup to me, 1440p 144hz is the tits. Will run the PG279Q till they die probally. Used to be a 4770k with 2x GTX 780's. More recently a 12600k & 3080 both on water self contained. Sent from my SM-S911B using Tapatalk
  3. This is for the rear PCV line that goes to the intake Manifold. I have 2 independent catch cans for the 2 loops. I dont remember what the stock one looks like any more.
  4. What check valve have people used? Was wondering why everything has been getting oily, my valve had failed and was sending boost up the wrong hole!
  5. Input on Selection plz. Mostly if anyone can confirm or comment on front fitment with 265's and if they will scrub. There's so much information on here, I've now learnt how to read wheel & tyre sizes. FG Ute, Custom trayback will be made to fit the rears. Will run at a reasonable height and not all tilty wheeled. Koya SF11 - custom offset, PCD, bore. 19" x 9" +28? Front 265/35/r19 ?? Anyone have input on this spec or how it fits??? My stock 19"s with 245/40/r19 have 10mm tyre clearance to the inner strut and this new combo should leave about 8mm inner tyre clearance. 19" x 11" +35 rear 325/30/r19 Michilin PS4S. May fit a 305wide for cheaper tyre selections. Limited by internal Brake line clearance, already tweaked the caliper hardline & chassie bracket for extra room. Has 45mm clearance to 245 tyre on stock 19"s.
  6. Indeed it was the fronts. @Slam it Im only 3 yrs late on the reply 🫠
  7. Modified my Tramp rods to have a Bushed end. Installed these rods years ago but removed them due to the NVH they caused; a direct metal link from the axle to chassie, reserved them for motorsport days only. Used a leaf spring shackle hanger & bushes. Cut them down and welded to an appropriately threaded bolt. Works excellently without the noise issue now. Such a more direct response from the rear end without the leaf springs winding up and releasing on each gear change. Little too late for my leaking pinion seal, & torn centre bearing though. Also a leaking rear main seal added to the 'Ignoring-till-its-a-bigger-problem' list. Sent from my SM-S911B using Tapatalk
  8. Paintless dent removal done on the ute today. Smoothen out 14yrs of shopping trolley dings and the creased bonnet. Got the headliner re-done in black at the same time, but the bloke knocked off early for the long weekend, so I'll be doing the next 1000km without half my interior. Some sort of paint correction next, probably ceramic coat and see what can be done about stone chips. Retiring the Turbo from work duties soon so I wanna get everything tidied up while it's still tax-claimable. Sent from my SM-S911B using Tapatalk
  9. Atomic Anchorlox. I've been through a bucket of nuts, nylocks, high tensile nuts, even nordlock washers on my turbo manifold. Finally paid up for the Anchorlox so they never come loose again. Sent from my SM-S911B using Tapatalk
  10. Cheers Puff! If that's the case I'm pretty sure Joe will keep her strapped down no problem. Sent from my SM-S911B using Tapatalk
  11. Heading back to my tuner to step up the power level soon and wondering at what point tyre selection is going to give the dyno man a hard time or affect results? Aiming for 400kw, I have a set of taller 17" 225 LT Van tyres (daily work horse with 800kg loaded tool canopy) and Nankang 245 Semi's on the factory 19"s. Neither I'm assuming would be optimal on a chassie dyno? Or there's the old dinged up 19"s with 10% tread trailer tyres. [emoji28]
  12. I'm with you in that they are a bit messy looking. Don't have oil pooling in the intake manifold any more though. No smells. They definitely work. Sent from my SM-G781B using Tapatalk
  13. First propper clean since christmas. Clay bar, decontamination, paint cleanse, wax, sealant, interior detail. New headlights. She's lookin pretty again! [emoji7] Thinking I'll dig up some old threads on blacking out the beige trims soon. Headliner has started delaminating. Sent from my SM-G781B using Tapatalk
  14. From memory, the factory cat and dump are the restrictions, so you can basically do whatever you want with the rest of the exhaust without needing a tune. Sent from my SM-G781B using Tapatalk
  15. I can always nit pick myself on what I'd do different next time, but realistically, Im very happy with how everything came out. Still looks like a 60's fibro shack from the outside, but that's a project for another year. Back to turbo things for a little while. And maybe a couple of weekends off if I'm lucky. Sent from my SM-G781B using Tapatalk
