28 ExcellentAbout rokkie
- Birthday 17/07/1985
Gender
Location
Adelaide, SA
That's what I was thinking. Cheers Sent from my SM-N910G using Tapatalk
You were right. When I picked it up it was a T3 flange gasket. Sent from my SM-N910G using Tapatalk
The only restrictor I knew about was in the core. If you talking about the inlet flange bolt which the braided line connects too. I tested it with that connected. I did drill out the ID to around 5mm. I'm agree that 2L does seem excessive. Good old mate Google recons 1 - 1.5L a minute is what should be supplied. Thought I'd ask the guru's Sent from my SM-N910G using Tapatalk
Hi all, I was wondering how much the oil flow rate to the turbo should be? I'm getting 1L a minute. The bloke who rebuilt the turbo said I should be getting at least 2L a minute. It's the standard gt3582 with a genuine Garrett core. I checked the flow rate with a cold engine and no turbo bolted up (didn't want to run the turbo with no oil supply). The viscosity of the oil is 15w/40. I have also removed the ford filter in the banjo fitting. Thanks in advance. Sent from my SM-N910G using Tapatalk
Mine cost me 900 fitted here in SA Sent from my SM-N910G using Tapatalk
Just throwing out there but the evaporator sensor was a common problem. Ford was probably talking about the a/c disable stradgey calibration. There was a tech talk about it. Sent from my SM-N910G using Tapatalk
I run kicker component speakers (6.5) through a 4 channel. Pretty sweet speakers. Amping them bring it to life. I thought the fg had a plastic moulding around the speaker all ready Sent from my SM-N910G using Tapatalk
And flush the lines in case you have swarf/contaminants. Some compressors come prefilled with oil. Sent from my SM-N910G using Tapatalk
I took my turbo off yesterday. Used this ratchet with a wobbly extension and deep reach socket. Apparently a silvia flange gasket will fit in between the turbo and manifold. So I'm told (adelaide turbo services). Apparently a metal gasket.
Trying to sort out the cga converter loosing its memory. As in position, contrast and brightness. As soon as it looses power settings are gone. OS has a few but the bloke who programed it all ways keeps updating his distro. Would love to get GPS and DTV incorporated to Sent from my SM-N910G using Tapatalk
- 49 replies
- ICC Color screen
- learn how to make pi
- (and 2 more)
I used a hdmi to vga cable into my cga board ($30 ebay special). Running a raspberry pi 2 b+. Running retropie distribution and openelec. Still ironing out the bugs though https://youtu.be/uO_U10YgFmo Sent from my SM-N910G using Tapatalk
- 49 replies
- 1
- ICC Color screen
- (and 2 more)
Could it be the connection under the icc on the tunnel? The one with the white pull tab. Center console has to come out to reach it
Money's on a connection. Sounds like a missing CAN signal. Double check the l/h side orange & white connector also the HIM module (vent controllet)
X4, injectors and tune. Economy didn't change for me. It is only a BA though Before and after 360km to a tank but now with an extra 100rwkw. It is running rich (better than lean) though.
I paid $3300 including valve springs at Graham west. Very happy with his work
