jas98
    2
Everything posted by jas98
  1. I have a blue connector sensor that I got with a cat I had. I have a BA xr6t which has one green sensor only (no blue). ford told me the blue ones are 250 new and green 140 if your after a blue one I have one for $40 works perfect as it did on the donor car
  2. never seen mine do it.
  3. your turbo will spin backwards and unicorn will blow out the exhaust with magical dust.... It will not harm it
  4. with a side of piston?
  5. that's the same company that aslo told me not to use there 7psi actuator unless I have a tune afterwards......
  6. As said will need a different actuator, if your handy with a spanner you could install it yourself
  7. boost leak for sure
  8. so far cheapest I have come accross is 300 bucks. however as mine has the center UNI joint as long as I can get one from any other car with same uni joint as the rear CV is the same turbo or non turbo BA (going by hardy spicer)
  9. plenty or people with large power stick to genuine throttle body for a reason
  10. hi I need a new cv joint for my tail shaft its the rear one. does anyone know besides hardy spicer that sell these? and im not after stupid power etc just a standard replacement. I know commodores ones are like 40 bucks but I doubt mine would be haha
  11. on a stock xr6t ba would the f6 snocle make a difference? for sum reaon mine has 2 holes cut in the areayou have shown but no snorkel etc.....
  12. I had same codes however mine is untuned. I replaced 02 sensor but still there after fed days, also running bad at idle etc. after a few weeks I got hold of a new fuel reg chap as chips so replaced it but as soon as I removed the clip for it I could tell something was wrong. the little oring in it was split so I had low (?) fuel pressure and im guessing somtimes allot? after that codes went away
  13. either: new nut or some lick tight but must be dun up to 255nm to 305 nm, 9pretyty sure my book says front are 255nm and rear 305 nmm but I did all up to 305 nm)
  14. thanks! both sides of the cradle are the same so im thining its just one of fords little stupid things like any manufacture lol
  15. yeah that's what I was thinking, it just would be better for future if the bushs ever needed replaceing again. the only reason I can see why would be because its easyer to get to, but any half decent shop coud see there in back to front and tighten lol
  16. nah the one the springs sit on it bolted under the diff, thts the other arm that's bolted near the fuel tank etc
  17. Ok this may have been answerd before so sorry On the rear of a BA (BF etc) the lower control arm that the spring sits on, the bolts that hold it to cradle you have to take the diff out to remove. is there any reason why I cannot put them in the other way round to make it 100% easyer to remove if need be in future? as I have to take diff out in comming weeks anyway. is there a reason why there put in that way??
  18. how an you tell if it need replacing? I know on commdores they make a pretty noise lol mine on me BA xr6t is still original at 240 000 k's
  19. well been a couple weeks since installed and they seem fine, will keep an eye on them
  20. need one of these
  21. nah, looks fine to me, splits in them areas mean nothing its only the solid parts that would cause problems as where that split is its just a very thin bit of rubber, part of the manufacturing process
  22. Seems tobe allot of this lately. Ijn checked mine the other week and bent those tabsbs bk in as it was almost popped out. Lucky I got it in time
  23. yeah its mainly labour costs. I have herd of the cradle being droped a little to do diff bushs but never herd of it staying where it is to do it without (as mentioned) drilling a hole in spare wheel well
