jas98
    2
jas98 last won the day on January 6
jas98 had the most liked content!
50 Excellent
About jas98
  • Birthday 10/11/1989
    Maryborough Qld
4,368 profile views
  1. Hey thanks. I did check all this but wasn't the issue. The issue was a weired one ....after all the crap I swapped I decided to remove the pcm ..unplug the connectors and reseat the connectors/plugs. Bolt pcm back and also I added 2 new earths from battery. One to engine and one to chassis. In unsure which of the three had an affect but it's been 2 weeks since and it hasn't done the issue since. The earths are just a temp solution as I'm going on a long trip in a couple days and honestly do not want to disturb the car as it's being good since I done this stuff. So it either ra bad ground from chassis to engine....even though the strap looks good etc and clean and connections are clean or it was the one from battery to chassis ..but it's been replaced 6 months back and is clean Orr it was a bad connection at PCM Either way it may or may not show it's ugly side again. Anyone who has similar issues if suggest reseating the plugs on PCM anyway a d checking earths
  2. Hi all what would cause a Forced limited shutdown And maximum speed reached Codes at startup...not all time but can be when cars cold or warm. Downt matter Ot started revs up and the missfired all over place till turning off. And on again then will drive fine etc Also while just idleing normally it will do same ....idleing fine then all sudden does this. But as said not all time Throttle body and TPS replaced every other sensor knowm to man kind replaced bo vacune leaks etc wireing looks all good have reseated the wireing into ecu...earths all good. Only thing left is pedal sensor and PCM
  3. Ba xr6t Been having an issue for a few weeks when randomly at idle car mite be idleing and all sudden for a split second missfired but at same time it revs up quickly and is all good ...this all happens within like 1-1.5 seconds. .other times when it does this it does same but besides revung up for a second it revs right up and missfired/stumbles etc till turn car off and on again . Mite do this a few times over say 4 days then comes good for a week or so and then does it again. When driving car it's fine...dosnet do it or miss etc only seems to be at idle Codes I get are related to excessive rpm ..and maximum speed reached codes Also I have tried a different throttle body and TPS. Which it came good for a few days after that. There is no intake leaks etc literally covered everything besides maybe coils? But surely it would do it while driving aswell bot just idleing? Also thinking possibly wireing issue to throttle body but again why only when idleing?
  4. Hi all. So I discovered that the water line to turbo was completely flogged on my ba xr6t ...nothing getting through Long story short it's all good now (new line) But .I'm in no way of knowing for how long it was this way. Jidgeing by how it was clogged I'm thinking it was like this for quite some time..as in allot more the. A year...maybe 2 or so Now turbo seems ok. But what is the likely outcome on this? Stuffed bearings? Oil seals? Also wondering...seeing turbo was getting really hot with no water cooled ....can it. Affect the oxygen sensor readings?
  5. I'll check resistance and see what they are. Car now does go better. It's throws U back in seat when it's comming on boost now. And smoother when over taking from say 90kph to 110 just acceleration at that sort of speed is much more smoother
  6. Update. Put in new cam solenoids and also removed the cam caps and cleaned the filters on there..and so far so good no code has come back .....so looks like it was either the solenoid or the cam filters
  7. But yes also codes come back after a couple days so I'll have to check timming ...I'll remove comer in next few days and see
  8. Also do the cam phasers fail on these? Cars done like 406 000 ks on engine and on startup sometimes there's a rattle from top and for say 2-4 seconds then instantly quiet again. Or can a cam solenoid also cause them to rattle at amstart up? As I know there's a pin in the phasers that locks etc
  9. Changed both cam sensors with a couple spares I had other day. Car seems to be idling slightly better but it never was a rough idle anyway . Anyway checked codes before and code was there again however I can't remember if I cleared code or not other day before sensor change. I've been reading and usually that code is a skipped chain but also a vct oil supply issue aswell. I know at start up sometimes there a lifter tick (very loud) that goes aways after like 5-10 seconds that it has had over the last couple years but always comes good ....unless if the vct solenoids causing it but there like 2.5 years old..ultra tech branded ones Other thing is if timming has skipped surely there would be another code aswell plus I would assume it wouldn't go as good as it does and idle would be bad? I will rip cover off and check timming marks anyway and... Yes I need to monitor and log ..but I'm trying to work out how I play back on forscan to watch it haha
  10. Awsum yeah I'll do that. Also just thought and also read that the cam sensor can cause stalling ...can also cause that code to pop up (and also no code sometimes) and a few symptoms I've had in past and I know it's the original sensor ...I have. A spare one here so I'll chuck it on and gox from there aswell
  11. I can get a better log later but this is what I mean. Someone told me that it looks fine...but yeah obviously not haha
  12. Well when I revit it seems to go to 0 on both It's hard to tell. I do have a vid but won't upload due to it being to large file
  13. That's will do. Also do these filters have to be installed or can be left out? And also if it had low oil pressure could that be an issue? Surely I'd have other issues. I just say that as I read a post about someone have low pressure causing codes
  14. Hahaha So....it still drives etc but yeah that would explain fuel economy issue I guess 😂
  15. Have done a small log. But U sure wtf I'm looking at really ...also while I was reving the engine gentlely at about 2200 rpm and took foot off accelerator slowly it stalled like instant stall...no splutter etc and wife also told me now it did same other day for her. But yeah the VCDADV2 and the VCDADV were both at like -9 to -10 at idle...when reved they did drop near to zero Vcadverr ones were basically 0 or went to 0.33 etc
