Bara58
36 Excellent
About Bara58
  • Birthday 19/02/1958
    Bowen, Qld
3,382 profile views
  1. Merry Christmas to all, as above, stay safe.
  2. OK have found the last run file I had on a usb drive, I'll put it here but may not work, if not pm your email address and I'll attach to an email. See below or the attachment? XH GTX3582R 1000 cc injectors and new cam settings (2).pcl
  3. http://www.vi-pec.com/techdata/documentation You should be able to get your wiring info from the above link, I used to run a vipec v88 in my XH with turbo Barra unfortunately don't have any of the details anymore (gave it away to the bloke that bought the ecu) but you should be able to work out using the ViPec site pretty easy the 88 will run the ethrottle as well. Don't know if this helps but this is the I/O schedule I used sadly I have deleted the tune but will keep searching as I might have a USB with a tune that will get you started.
  4. Get BA wiring and BF wiring diagrams, ECU pin outs are different between the two!
  5. Bara58
    Winch
    Good winch, never had a problem when I had one on my pootrol!
  6. ^^^, Bowen, just sitting here waiting! At this stage will be a direct hit, so maybe not so bad, depends how slow it moves! Haha, hope you get some to! Stay safe all you guys in the storm zone
  7. Haha ^^^ still pissed off waiting for this debbie biatch to bash us!
  8. This thing, and i'm not Rab
  9. http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&cad=rja&uact=8&ved=0ahUKEwih18DNuobSAhVGHpQKHWYsCrgQFggoMAU&url=http%3A%2F%2Fwww.ebay.com.au%2Fitm%2FGENUINE-FORD-FG-MK2-FALCON-XR-6SPD-MANUAL-GEAR-KNOB-AND-LEVER-ASSEMBLY-BOOT-%2F301677440576&usg=AFQjCNH9JHHPWeAUwMErc7NN8ZoiBZWsiQ Try this one, I bought one in December, good so far!
  10. this is tazzanz
  11. ^^^ http://www.ebay.com.au/itm/F150-MUSTANG-EXPLORER-TA-PERFORMANCE-DIFF-COVER-/320779173168 Have a look at this one
  12. Wiring4 Electrical.pdf Has courtesy lights wiring on page 20
  13. Hey Bud, I have a Xcal 3 unmarried with 5 unlocks, $300 posted if you are still keen
    laurie
  14. Bara58
    Sump removal
    I think from memory fly can stay on, should be able to see them there are cutouts at the back on the flat part if that makes sense! Sorry Luke, you beat me to it
  15. Bara58
    Sump removal
    Don't know what happened here, the bit I put in disappeared was supposed to be pic of sump bolts!
