g5jett
About g5jett
  • Birthday April 8
    hampton park
  1. Happy Birthday g5jett!
  2. Happy Birthday g5jett!
  3. Ok cool thanks doddo! nah that's ok the great thing is they are all bellow $100 A is most expensive but still a great price.. I dont wanto spend to much just want a lil bass.. cheers for the reply..
  4. Hi All, So im not to crash hot on sub specs and witch would be best, So if we said, what would you choose A, B or C out of the below options.. Let me know your thoughts A) SUBWOOFER SUB 1000 WATT 10'' 1000 Watt Ultra Slim DVC SubwooferHigh Quality Poly Mica ConeButyl Foam SurroundDual 2'' High Temperature Kapton Voice CoilIndependently Fused 20 Amp Speaker Terminals60 Oz Magnet StructurePower Handling:500 Watts RMS1000 Watts PeakFrequency Response: 30 Hz - 2.2K HzImpedance (Per coil): 4 OhmFs: 31.7, Qms: 4.07, Qes: 0.46, Qts: 0.41, Vas (L)49.69Efficiency: 90 dBOverall Diameter: 10.6''Mounting Depth: 3.08''Includes Installation TemplateWarranty 1 YearB) SUBWOOFER SUB 600 WATT CX10: Power Handling:Power Peak: 600WRMS: 300WCone Material: Poly InjectionFrequency Response: 30-4.5000khzImpedance: 4 ohmVoice Coil Size and Type: 1-1/2"Efficiency 1 Watt/1 Meter: 92dBMounting Depth: 3-3/4"C) D10F: 10" Single 4 Ohm Diablo Series Shallow Mount SubwooferPower Handling:Peak: 800 wattsRMS: 400 wattsImpedance: Single 4 ohm2" voice coil60oz magnet structureFrequency response: 35-22000 HzPoly injection woofer cone materialButyl rubber surroundSensitivity: 94 dBTop mount depth: 3-3/8"1 Year Manufacturer WarrantyAll the above specs are all of 10" sub examples.. Cheers in advance..
  5. Hi All I know that this is an old thread but I am curently installind a 4.3' screen and a boot mounted camera.. the screen getts its power from the cig. lighter (putting out 12.49 v) I wired the camera into the reverse light and when I connected that nuthing! when I tested this point was only putting out 10.49 v whitch is not enough to runn the camera I know this cause I attatched an external 12v dc power source just to check and it all works fine.. so my question is, were can I fin a strong 12 v dc signal that only activates in reverse..?? Cheers in advance..
  6. Well it got the better of me I tool this thing out went to the servo.. and might I say, very dissapointed! the sound was hardly diffrent and the power was exactly the same if not less responsive down low from what I experienced.. so any one thinking about this unless your getting your car dyno tuned I really wouldnt bother with this.. Cheers again for all the imput..
  7. Hmm yea I listen to a lot of rnb and house music at times... I see, well I'm thinking that I should do away with the 10" box I have and just go for a pre fab 12" sub and box from auto barn or somthing... Some of those subs are around 1200watt but only about 200w rms, your saying this would be better than the 300w rms 10" ?? Cheers..
  8. Ok thank you, So the rockford I was looking at getting is the 10" shallow punch p3, 4OHM,600watt, 300w rms, response 43-250 hz, sensitivity 83 db.. hope that's enough info..?? how dose that sound..?? Cheers..
  9. lol yes true.. ok so probly looking at a rockford 10" 300w rms sub and amp now.. I also had another idea... I was looking in the boot today and realised that the car has the cut out in the pacel shelf for the 8" sub what would be better sound an aftermarket 8" sub and amp in the pacel shelf or my first idea of the 10" in the boot... thanks for all the help!
  10. I went down to my friendly local jb store yesterday, I was looking at a cadence sub and amp combo the guy there said if I was to get the amp that he was showing me basicaly I could just get standard rca cables from the amp cut the ends of the leads and just tap them into my rea speakers... no line converter nothing? Dose this sound right? if so its starting to sound pretty easy now :-D
  11. hi im thinking about tuning my 2008 xr6 n/a just wondering what plug in/computer was used to tune the ute? (eg: kappa flash ect?) cheers..
  12. cheers BRK ill have a sift through
  13. Yes probably the best idea Bellato.. I gess last of all, im looking at a 10" sub most of all because of its size (I want to keep as much boot space free as possible) second of all I already have a 10” sub box and its quite shallow so I’m looking at the a 10" shallow. version of a couple of different brands at the moment, hopefully around the 300 - 400 rms range, dose everyone think this will be sufficient to hear some good bass? and what gauge power wire should I be running? Also with the amplifier I have to get something at least rated at 400 rms correct..?? Cheers..
  14. What is wrong with Kappa flash tune? in the past this is what everybody usto use on the turbos (at least version 1 & then 2 not to sure how ver.3 went never had any experience with it) at least I thought if its good for the turbos even easyer for the n/a ?? Anyway, what are people using? what mods? and what power has been acheived?? Cheers..
  15. Hi all, Has anyone tuned there fg xr6 n/a? if so what computer (eg:kappa flash) did you use? what other mods did you have? & after all was said and done was it worth it? cheers...
