Msg6et
1 Neutral
    Female
  1. so you can run all 3 guages to the 12v plug and its ok?
  2. Does the sandwich plate have end caps to block 1 of the holes? As I'm only using oil pressure volts and boost
  3. iv got an eaton trutrac and its the sh*t! best $2300 spent on the car!
  4. well I was going to stall it up to about 2grand running standard tyres tomorrow night
  5. stupid question but I have 330kws in my g6e. taking it to the drags next week on street tires has true trac. will the tailshaft hold up? cheers kel
  6. im also getting this problem right rear though sounds like a knock every time I pull into my drive and the rear tires hits the concrete
  7. looks like a xt with red rims on it now heaps cool :newrussian:
  8. standard turbo that's what kpm have told me
  9. every 1 may judge this but I got my g6et tuned at kpm on 13psi and got 328.6 atw beats me why u have to run big boost?
  10. hi I have high flow injectors running 13psi fg can u run a 50/50 mix of 98 and e85 without a tune? will it give me more power ?
  11. thankyou so much I'll plug it up. thanks kel
  12. hi every 1 sorry it's not in the right spot I have a fg and just bought a alloy expantion tank it has 4 tubes that come out but my factory 1 only has 3 is there a way I can fix this? I think the 1 I was sent is for a ba. any help would be great cheers Kelly
  13. What size tyres are u running on the stock el rims? Cheers
  14. What size tyres are u running on the stockies? Cheers
