kdd007`
2 Neutral-
Yes I did check all the holes and clips match perfectly fine. tried stabbing it inn real hard aswell. just feels like somethings in the way. might just let ford fix it when I take it in for my service.
Hey guys. This has really been frustrating me. So I took both the rare door trims out of my xr6T FG which was easy and perfectly fine. but when I try to put it back on the it just does'nt clip on properly and sticks slightly open from the top. (Photos attached). It just feels like some things touching somewhere. But I did spent hours but could'nt figure it out. However I have taken the front trims out and did'nt have any problems putting those back on. Do I need to put my window down while doing it or something. Let me know if you guys have faced similar issues or if there is any logic or trick behind this. Help much appreciated guys.Thanks
Hi guys looking to upgrade my 2009 xr6T FG. Non premium sound Was just going to upgrade the sub as of now will do the speakers later. I have been doing some research and is getting confused with so much information I will be connecting all this to my stock ICC. I know I need pre outs RCA since the stock ICC doest have any so after doing some research I have purchased the AUDIOCONTROL LC2i which I will be connecting to my MB Quart ONYX ONX1.1600 Monoblock amp and then to my Kicker 11VS12L72 sub. my main question is how do I connect the lc2i to the rear speakers wires.do I just cut the speaker wires and connect it straight to the lc2i or do I have to tap into it ( which I am guessing means making a slight slit between the speakers wires and soldering the Lc2i wires to the speaker with to make sorta like a three way connection.) Also do I need to find a remote wire behind the icc or do I just connect it to the cig lighter.I know these might sound like some noob questions but I need your help please.help much appreciated. Cheers
- 2 replies
- lc2i
- line converter
(and 1 more)
Tagged with:
dw guys was just doing some research and found this. Problem solved. Here you go if any of you newbies need it. http://www.fordaustraliaforums.com/forum/showthread.php?48120-How-to-remove-and-dismantle-a-FG-ICC-unit.&p=387188#post387188
Hey guys pretty sure this has been asked before. but need to get my dash taken out to get to the wiring behind it. is there a post already or can some one tell me how its done. Cheers for your help.
bionicxr6t05 your a bloody champ. woow it works now. its all set. but I swear I had tried that the first time initially but it didnt work. oh well at least it does now Thanks for your help guys cheers
Alright guys this is what I have been doing. either Fm1 or Fm2. then I press the scan/as button the display comes up as empty. then I press the seek up or down depending on the station and once I reach a station I like I press down the station one button and keep it pressed down untill the ST sign appears( dunno what that means I am guessing it means set). I continue doing the same untill all of my 6 stations have been set.I can now jump to any station I want and it DOES remain set. But I soon as a I toggle between fm and am it all come back to the default channels. Fuaaarrkk.. so frustrating.
Sorry I should have mentioned its a 2009 FG xr6T
Hey all been having trouble setting my fm radio. I set the radio but when I switch between fm1/fm2/Am it resets it's self back to default. Is there a way the radio should be set. just had the car for a couple of weeks now and its amazing. Also is there anybody or is there a topic running already on the names of the engine bay parts. I know it sound like a noob question. But I am having a hard time trying to figure out whats what in the engine bay. any diagram or pictures will be really helpful. Also let me know if there is any important links that I should have a look at. Cheers for all your help. P.S : sorry if I have posted this in the wrong section.
Hi all, Just joined this forum and this is my first post. Just brought a 2009 Fg XR6 turbo. can some of you forum gurus help me with these question. I know some might sound silly and simple, 1. Is there any way to find how much fuel I have left in my fuel tank in litres. 2. The RANGE mode of my Cluster is it accurate? It reached 0Km today and beeped but I could still drive it for another 2 kms is that right? does'nt that mean my fuel tank is empty? 3. How do I know when my fuel goes in reserve. How many litres is the reserve tank? Help much appreciated.
