geekatrons
2 Neutral-
Ba Xr6T Running Rough- Still Slight Shudder
geekatrons replied to geekatrons's topic in General Tech
Hello I will take to ford- I am in 2 minds- take to ford directly or take to a good mechanic? might just bite the bullet and tae it there. thanks for your feedback. -
Thanks guys- I will get a genuine o2 and put that in. The throttle body I have checked and it appeared to be clean. The engine mounts have been checked- will see how I go. Will keep you posted. -
hello when I stated in neutral I mean stationary also. I noticed something today, started the car up from cold and the when I turned the steering wheel slightly the vibration through the wheel was really bad- I went full lock from left to right and when turning right it squeeked a little. Could this be an issue with the power steering? As far as the speed goes it is no better or worse at speed- The diff is not noisy- (well typical noise- not crazy. I am at wits end at the moment. -
Hello the diff bushes are red. Nolothane from pedders- was shuddering before this. Also in regards to the o2 sensor I have already got a new one- been in for about 2 months.? not sure if this is the problem? unless is a faulty one? it was a different look to the original but assured that it is for the XR6T. ?? I have a mate who works for a diff place I might take the car to him and get him to have a look. -
Hello All Has been a while- I have spent a bit of time in the BA and getting things done. Recently got new rear shocks and diff bush done. I am at wits end as to what is going on with the old girl, when I start the car hot or cold and I get to the first set of lights and wait there the car feels like it wants to surge forward- the revs drop and it is at a stage where I think it may stall- gets to around 500 RPM. Once it gets going seems ok. I still have a shudder I am thinking that it might be buckled wheels- I have tried to put them at the back but I don't know what options I have other than buying new wheels and hoping this is the problem. Even at idle I feel a slight shudder through the wheel- would a tailshaft balance cause a shudder at idle? In drive or in neutral still has the same feel??? Please help p.s the shudder doesn't matter if I am doing 20Kph or 110kph still the same feel through the wheel- the passenger seat I can see shudder when driving also??? really bloody annoying
Hey all- Some things that you need to look out for- 1- Discs- if original will more than likely be warped- upgrade to DBA slotted and new pads- 2- Diff bushes- if clunking in rear end then probably need done 3- just point on discs once done may need on car machining as the hubs are usually a bit hows it going. 4- Coils common problem- need new coil packs maybe. 5- Plugs- they chew through plugs get new ones Hope the points help you- Also one issue I had was boost actuator needed done also
hello all- Update-I have got rear diff bushes done- and 2 x rear shocks done at pedders- Drove the car to brisbane from NSW- had a shudder the whole way- kept me awake lol. So I still have the following issues- shudder through car- worse when going down incline. and now an issue where the car with a splutter when waiting at lights- misses every now and again. I am going to try and get new rims as I think this may be part of the problem. Any other suggestions? I might get new hubs.
Ba Still Has Steering Wheel Shudder Any Speed!? Help
Thanks Guys- All will be revealed tomorrow at Pedders- I will get them to have a look at the front end- see how I go from there. I took it to another mechanic today who took it for a drive. He said that it drove really well- he couldn't feel any vibration- maybe I am sensitive to this stuff? I can only hope that I find the problem or I will have to wear padded driving gloves so I don't feel them- lol -
The feeling through the wheel is more of a shudder with the steering wheel feeling like it is shuddering up and down- not left to right like a wheel balance problem. I am so over trying to find the fault. -
Are there any more specialised places in Western sydney that will not rip me off and get the issue resolved that you know of- I am cutting it tight as I only have Thursday and Friday this week? -
Thanks Senna My understanding is the clunks from the rear and reverse to forward clunks are diff but I didn't think that wobble would come from diff. I don't want to spend the $600-$700 for diff bushes if this will not help the vibration. -
Hello All- I need your help I have had a few issues with my BA- I am getting pretty frustrated at the old girl at the moment. The issue that I have outstanding is a slight shudder through the steering wheel- and I believe there is an issue with the rear of the car.- feels quite a harsh small vibration/ shudder at any speed. What I have done so far- Wheel balances- A number of them completed at various different places. New DBA slotted rotors and Bendix brakes- Machined on the car- is not a braking issue. Had the wheels checked for bent rims- they are not too bad- a slightly buckled one put on the back. New tyres on front. Had the Bake booster adjusted. I have had the car inspected by my regular mechanic who has checked the control arm bushes and the diff bush and said that they don't seem bad. I have however had another performance company check the car and they said there are some major issues in the rear and said I need the diff bushes replaced before I have more major problems. Would Diff bushes cause my problem? I have booked in to get my rear diff bushes done on friday at Pedders but if this doesn't fix my vibration/ shudder issue I will be pissed. Diff issues- going from reverse to forward it clunks- over bumps is a bit harsh- no major whine- can hear it but nothing crazy- On the hoist I can see a tear in the rear bush- would this cause my issues. Sorry about the long post- I am desperate- If this isn't the problem- Ideas? I need a solution as I am going to the Gold Coast on Saturday :0)
Slight Shudder From Rear When On Idle?
geekatrons replied to geekatrons's topic in Driveline Workshop
in neutral- feels almost like it is trying to surge or some tension there somewhere. -
Hello All 2003 BA XR6t 100k on the clock. When I start the car it idles a little rough but the main issue is there is a slight shudder through the car coming from the rear- can feel it through the car itself. Any ideas- driveshaft balance problem? I am unsure what it could be? You help is appreciated.
High Fuel Economy 18-20L/100Km
geekatrons replied to geekatrons's topic in Fuel System & Induction Workshop
Hey sorry just going through old posts. Update is I ended up getting a new turbo actuator which helped an overboost problem. I got a new o2 sensor which has dropped it down to about 16.2l/100 I am going to disconnect the piggy back tomorrow and see how I go. Will update once done.
