boosted_rhino*
3 Neutral
About boosted_rhino*
    melbourne s/e suburbs
  1. snap z2tt is right. so cams are overwhelming in performance but since your not going ahead kpm so you get customers to spend that on other developments ..... if that's the case boys just need to pick a grind from lunati or comp cams they have specifically for superhcarged coyote applications and give it a go
  2. Hows e85 availability? I only run e85
  3. Dw tony you will get all the points for cleanest xr6
  4. So if yours is lowered and going to be wider and bigger in diameter than mine I reckon on corners will touch. Just to be more specificy tyres 275/40/17 Mabe if you get low profile might help or stiff suspension
  5. Nelsonian I am running 17x9 + 22 offset all round on my fg stock height as circuit wheels. No issues at all got 275 nt05 semi slicks on back only touch the guard on very hard corners... from body roll. .. still got standard suspension. They stickout real nice
  6. I'll come my cars pretty fat on the outside... just don't look inside lol
  7. While idling with multimeter comes up with 13.3 v apparently should be 14. I will do same as you have hawlass just to be sure that isn't the problem
  8. I relocated my battery to the boot. used 0 gauge positive cable to the front like in the picture above in the how to . I have one 4 gauge going to existing negative terminal up the front and one short negative cable in the boot bolted down. my car surges sometimes it stops and sometimes it starts the moment I slow down and stop at the lights just surges for 30 seconds then slowly stabilizes, if I chuck aircon and all the lights on and the revs start to surge and the lights go weak as it surges down and up any explanation ?? maybe I didnt earth right ?
  9. Has anyone tried the gtx3576r ?? I'm keen on going with fast spool. Currently making 352rwkw on fg turbo on e85 I want to go a gtx3576r run less boost make about 360 rwkw with better top end obviously. Sorry hijacking thread
  10. Sorry for late update, its a auto, turned out real good just like fletty explained no drone on freeway at all to me its just perfect, sounds as tuff as it gets for the xr6t will be loud off lights if you got a heavy foot pull off lights like a toyota prius its not too bad, will try and get a nice video. Straight 3'' at back with twin 3'' tips, should of got a quadssetup while I was at it
  11. Nice, ill put up a video, hopefully my new fone will record it with decent sound quality, as Videos arnt as good compared to hearing it live
  12. Ok so I woke up this morning and randomly called up nearest exhuast shop and droped my car off for Rear muffler removal, 3" straight pipe with twin 3" tip, the night before mates ba turbo rear muffler removed sounded pretty good, and fletty's post motivated me to get rear removed. The video of Ute with rear removed sounded better then centre muffler removal. Hopefuly will sound good ! I understand by not getting a hotdog that it could be loud, but I like it loud !
  13. Just wondering if I could go 20"x9 on the front and 19"x10 on the rear, I'm planning on using enkei wheels or even 19" front and 18" rear with fat tyres for the purpose of going to track, and high wall tyres for the rear for launching now and then, would I be able to have the fg sit without having the back end lower than the front with the right profile of tires ? I'm willing to pump out guards as much as they can be with the fg
  14. thanks ratter, I had a feeling there was a reason why so much more cheaper from usa sorry for doing a repeat
  15. hi guys I did do a quick search but couldnt find what I needed so I hope this helps others aswell I would like to know if I ordered a sct xcal x3 from a usa seller on ebay for $360 free shipping will a tuner like nizpro, pitlane ect.. be able to tune with it ? thanks in advance
