ryancross
Inactive Members
  1. HI, Thanks for the tutorial, saved me a bunch of cash. I did this over the weekend and only took me 3 hours from start to finish. A couple of things: It is a 5mm allen key needed for the dash bolt up near the windscreen, (not 6mm) Part was $60 from ford, and does have the re-inforced metal rod now. Once all put back together I found the airbag light would flash and stay on after this. I was dreading to have to remove the dash again to fix, however I found a yellow plug down between the drivers seat and door had become unplugged. Plugged it back in and the light has gone away. If you follow this tutorial to the letter, you should not have any problems. Thanks again
