Soxtyfoonf6
584 profile views
  1. Not the case , car could be sitting in the garage for a week & it would be the same thing!! .. “TRANSMISSION FAULT” Saying that I’m not to much worried about it now cause E70 is no longer available, I’m waiting to see my tuner now so he can tune & install E85 file
  2. Running two custom tunes 98 & E70 , had my 98 tune sorted regarding idling issue , which was all sorted, ... Finally wanted to switch to E70 tune using XCAL3 tune file , E70 file tune finishes & Transmission Fault came up in dash , Car now doesn’t allow transmission to change gears ? Stuck in 1st gear ?? What’s going on here??
  3. You have to go to Sydney these days for modifications & tunes cause no-one in Newcastle can do it !! They are all DONKEYS
  4. Just yesterday I had 30 km left of E70 left in tank , & I changed to my 98 tune , Now I did this prior of going to the servo to get fuel which is just 10 minutes from my place , When the loaded file was finished I turned car on & it would not idle , finally car idled for a while to make to BP servo to fill up , now the car every now & then car drops revs & stalls at lights , why is this happening??
  5. Soxtyfoonf6
    Stalling
    2010 FG turbo Auto , running 1000cc KPM injectors with twin pump KPM intank setup , but running standard fuel regulator , since tuned car not all the time will drop below 500rpm & sometimes stalls , tuner has told me need to upload the file tune to compersate for injector scaling to be right . Car currently running on Efex
  6. what is a safe offset when running 9.5 inch rim with 275/30/19 for a fg sedan , im in the stage of waiting for wheels to arrive with +35 offset , have I got it wrong ??
  7. hi fella's im new to all this but I'll give it a go ! will a 9.5 inch rim with a +35 offset ,with a 275/30/19 tyre fit under the rear of my fg turbo sedan ?? im running pedder coilovers , is there going to be clearance inner& outer comments appreciated thanks
