patrick1234
3 Neutral
  1. Thanks *Just saw my double post
  2. ralph , which ones are they?
  3. ralph , which ones are they?
  4. Ok I might take my car into my tuner and ask.Woulf cracked housing cause loss of power?
  5. Thanks for the replies... so basically what are my options? performance doesnt seem affected.. well I dont think
  6. See the bolt missing and the one down futher half way out. . they are on the turbo exhaust side
  7. Hey guys, not sure if this is the right place for this but il try anyway. I have a bf xr6 turbo ute and 2 bolts on the exhaust housing have come loose and one has completely gone. I meant these little bolts holding some sort of plate on the turbo. So my car has a funny sound and "Burgels" out the hole where the bolt should be,. I tightened the two loose ones and they worked there way loose in 1 drive Il put up a photo tommorow. Was wondering if anyone else has had this issue and if they know what size bolt they are. I have tried 2 from a bolt in with no luck, And ford don't stock them cause its off the garret turbo
  8. You need a tune bro, I put an exhaust on a couple of months ago and I took it to a dyno just for a power run and it was leaning out way to much, the guy stopped the dyno so it didnt blow up. And my boost also went from 10 to 18 psi
  9. More or less im about to go get it properly tuned and was going to buy new injectors, but if they have been drilled I dont see the point. It was just wierd that it was running so rough
  10. Well that's kinda what im trying to find out, the injectors are just the normal blue, but they said they were "bigger" but he didnt do them
  11. Hey guys so I finally got my sct x3 which came with my car. Anyways long story short I was playing with the unit and decided to try it back on stock. The car ran rough and when I put my foot down in 3rd it would shutter and lose power. Can anyone explain why this would happen? Thanks Bf 2006 xr6 turbo ute
  12. Hey, would anyone have a sct x3 for sale which is unlocked?
  13. Nah just installed exhaust yesterday, will get it tuned within 2 weeks, and yeah I like the note bit quieter on idle but more deeper under boost
  14. Hey guys just an update! I bought a full system from someone in here, installed it today and im definitly impressed! pulls way harder although I notice my boost has creeped up to around 14
  15. Nah I mean to fit the cat onto the existing exhaust
