csr20
2 Neutral
About csr20
  • Birthday 30/08/1981
    Mackay
  • Interests
    cars women and music
672 profile views
  1. Happy Birthday csr20!
  2. Happy Birthday csr20!
  3. Happy Birthday csr20!
  4. Hi Guys, What's the best well priced solution for a turbo side intake & battery relocation kit to suite a G6e Turbo compatible with a process west intercooler. Rapid used to have them on ebay, not sure if they suited a process west cooler though can anyone help? The process west setup is quite expensive.
  5. Thanks mate, I'm booked in for a process west intercooler, 15psi wastegate actuator change and tune, wish me luck.
  6. Hey Hyped, you could be onto something here, my diff bushes are f*cked!!! Champion
  7. Dave reckons the stock actuator spring is strong enough and that he has done many xr6 turbo's g6e's and even f6's with the standard actuator with no problems at all. From the feedback I received today it sounds like I guess not all actuators are made equal, how many people here with FG's have actually had this problem and just rectified it with a heavier wastegate actuator? Thanks Chris
  8. Thanks for your help guys, Dave's known to be one of the best tuners in Australia, he has done this cartridge change many times and said he always uses the standard wastegate actuator and tested this one on the dyno and everything seemed normal. Moving forward if it is the wrong actuator does this mean that the flap could be opening prematurely and losing boost? What is the right Actuator and where can I source one? Can it be swapped without to much trouble? Thanks heaps guys I wanna put this to rest.
  9. sorry Ratter, Dave used the actuator from the Standard FG turbo.
  10. We just swapped out the standard FG turbo for a 35/40 cartridge and ported the wastegate at the same time. Problem is boost hits 18PSI but tapers off to about 12psi at redline. We have all the standard supporting mods ie cat, injectors, intake, xcal but have kept the STANDARD INTERCOOLER. We have tested the wastegate actuator and checked for any intercooler/BOV leaks on the dyno. Do you think the standard intercooler could be hindering the performance that much, if not what do you think it could be? We were thinking next to check the cat, it is however only a 6 month old 100 cell cat? G6E TURBO 35/40 ID1000'S XCAL MODIFIED INTAKE K & N 100 CELL CAT MACKAY - DAVE S
  11. Hey Guys I'm upgrading the turbo in my FG G6e Turbo to a BF MKII 35/40, which Earls filter do I need, can you recommend the right part no, and or item no on Ebay please?
  12. Happy Birthday csr20!
  13. hey Trav, congratulations mate, awesome time, I've got a video of your car if you want it.
  14. csr20
    Trav199 G6Et
    that's one hell of a sleeper, nice work. David does great work.
