trentlikeshp
26 Excellent
  1. for those interested, manifold is complete, blasted, painted and bolted up to the motor. have adapted/ made oil and water lines to suit. have all the gear apart from mufflers to get my exhaust done, just need to weld a vband flange to the turbine housing as I'm doing the entire exhaust with vband joints
  2. got all the pipes welded yesterday, gotta piece it back together and weld to the header flange and collector pipes and pray they haven't distorted too much (fingers crossed) then mill the flange surfaces nice and flat if need be and take to work on Monday and have it blasted ready for coating. then all down hill from there making an exhaust
  3. oh and the photo of the turbos is just a comparison, not hard to figure out which is which lol
  4. cheers mate, really appreciate it [emoji2] I made the turbo flange and split pulse collector (no particular knowledge or 'proper' design with the collector, I was just winging it) splashed out and bought a laser cut header flange because I'm too lazy to make one. I made that jig for the flange placement off a 6boost manifold that I borrowed from a mate. however his manifold was for a gtx45 which puts the turbine all but right against the rocker cover which I didn't like. seeing the t51 is a lot smaller, I moved it toward the strut tower 20mm and forward 30mm (hence why the collector is clamped to the jig and not bolted) and then basically just played join the dots while trying to not screw my own ass by making it too hard to get a dump pipe out the back or getting the hot side onto the comp outlet. I lobster backed the intake with some 3.5" exhaust pipe that I had laying about which will be getting ceramic coated along with the manifold and maybe dump pipe depending how the cash flow is at the time. and that's about all for the moment
  5. having drama uploading. if someone wants to volunteer to post them for me I can email/mms some photos of the mythical recent work [emoji13]
  6. haha I was waiting for that
  7. bit of an update. manifold is all fabbed up, just have to pick it all apart and weld the pipes up. once the turbo is 100% home I'll start to knock up an exhaust. also fabbed up a neat lobster backed turbo side intake too.
  8. thanks mate, I'm no gun mechanic but I don't mind giving it a go. my dad is a fitter/turner of 40 years and an ex drag racer so I've learnt quite a bit from him. as for the wastegate, I'd be pissing into the wind trying to give you a straight answer. but from my own experience it seems to help with smooth boost control upwards of 20 pounds (I've never ran any less) hopefully someone else can answer properly
  9. it has no turbo badge, can't see the cooler and it's pretty quiet (for now) so it's kinda sleeper ish.. but yeah it's no taxi on stockies. I'll give that a go ralph
  10. my tapatalk app reckons it needs updating but needs current IOS software which needs to be updated while connected to wifi which my phone refuses to do.
  11. kinda gay I can't post photos BUT I have my manifold almost finished. at which point I will then move onto fabricating a 4" exhaust right through
  12. okay so I acquired a T51r as a clean swap for my gtx supercore. which leaves me with a few left over goodies that may be of use to someone else. have a factory ford b series turbine housing set up for external gate, 4" xforce dump pipe , 3.5" stainless cat and APS stainless cat back exhaust to suit b series ute (may fit FG but I don't know) having trouble uploading pics so pm me for my number or further info
  13. yeah I was worried about running out of legs before getting through the traps.. I have the issue of not being able to use 17s due to the lowering blocks. I use pre AU 15s for skid wheels but they're only pretty narrow so I don't think they'd be much chop for the strip. I could use 17s but I'd have to raise it back to stock height that's all Sent from my iPhone using Tapatalk
  14. yeah I'm keen to hit the strip, just gotta sort out tyres.. what size would be a goer for 3.73:1 ? Sent from my iPhone using Tapatalk
  15. dominello 3000rpm stall Sent from my iPhone using Tapatalk
