browny_5134
1 Neutral
    melbourne
  1. hey there just letting you all know that it turned out to be the transmission has a broken forward gear the car is being towed to mechanics this week let you know what exactly went wrong and how much to repair also thanks for the replys! cheer anthony
  2. browny_5134
    at calder
    hey bro nice car engine bay looks very neat "sleeper"
  3. Hi guys,jacked the car up did what you said to do its still locking up like I said I can drive forward but not in reverse even when the car is in "N" you can't move it.I think its the auto or converter has anybody had this same problem? regards anthony
  4. Thanks guys I will check on both the handbrake and rear calipers once I have determined what it is I will post the results! regards anthony
  5. hi there,can someone shed some light on this situation please I to had problems with my diff bolt ripping out of the diff backing plate had drop the whole rear end to get to the bolt out then have my backing plate ezy-outed then rethreaded and put all back together it was fine for about 2 months then all of a sudden I went to reverse in my driveway and then I heard that familiar bang so then I jacked it up had a look at the bolt seems to be ok not loose or broken.When you select the reverse gear it wont make the thud until you accelerate so I got a second opinion he reckons the bush that surrounds the main diff bolt is what he called nested,cracked he said you have drop the rear end again to fix (fuming by this time) then I get home put it in reverse accelerated bang but this time after the bang it would not reverse then selected drive to go forward it went forward but it felt tight as hell I also noticed while cruising if you took your foot of the accelerator it dosent roll freely like driving with the handbrake on just a little getting back to the main problem no I cant move the car in neutral it wont roll back or forward can someone give me any ideas that might help? cheers anthony
