BRK
67 Excellent
About BRK
  • Birthday 06/11/1953
    Perth
  • Interests
    All things cars.
    Very partial to a bit of quality boxing.
    Staying in the workforce. Retirement is bullsh*t.
  1. CJF077
    Happy Birthday BRK!
  2. So, I go to get a new set of rear tyres and put the rattle gun on the wheel nut and one of the nuts just falls off with half the axle stud inside. Ok, stuff happens so better get a new one. Well, hang on to your wallet. One genuine Ford Rear Hub Stud at retail = 36 bux. Got to 30 in the end. I think that is a wee bit excessive price wise.. I just hope I can get the old one out without pulling the rear hub off the car.
  3. Do some thread mines on this. APS did a lot of early modification work on the BA Turbo when released and their site still has some of the early data. Note that they then used a unichip and we know tuning software has moved along since then.Their results at the time spoke for themselves. Kits were well made in that the parts worked and were not troublesome to fit. Their Phase three kit in a manual BA with a 5 speed and a 3.23 diff ran 307 Km/hr at Avalon airport with an advertised 390KW at the engine. Their were other pioneers at the time and things have progressed accordingly. If you want to relocate the battery within the engine bay, pay close attention to the frame they made up and the path of the I/cooler pipe work. A gel type battery can also be used - look at the Nizpro site. Or, you do the boot relocate - plenty of very helpful threads on that approach. E34 BMW 5 series sedans have batteries under the rear seat. The Ford has no space to do that unless you went to lithium batteries....... hardly worth it.
  4. We all get caught with something. Had a 540 V8 BMW that I wanted to burn.......... (Nicasil issue in the block plus a boring list of other tedious faults.) BTW.......My missus reckons I had my odometer wound back and whoever re did my upholstery forgot to take the sag outta me ar*e end. Gotta bit of knock, ping and blow by first thing in the morning as well.
  5. Never stuck a dial guage on the camshafts however, the workshop I use have. The BA turbo cams have less timing than the BF. They have not bothered with the FG. The VCT system in BF onwards works on both camshafts. The VCM tuning packages allow for some changes in the operation of the VCT. Minor adjustments within this system does not seem to produce marked changes in power but my observations of this are limited to a couple of minor adjustments made to the tune in my car and in the end, they were put back to stock. The only "cammed up" xr6t I have seen on the dyno was unimpressive. Had a slight lope at idle, power curve favoured the top end and road manners were ordinary. IMO, the owner would have been better off winding in an extra 2psi of boost and would have got a better result. His bux, his choice. There are others on the forum who have asked the same questions and others who have looked at ( or undertook) cam changes in-depth. IMO. for overall power and driveability in what might be called the "useable rev range" - being idle to 5800 rpm - stock FG turbo cams ( with good springs ) are the best. After that, go to the aftermarket.
  6. Guys - hearing a strong rumour that Perth Street Car Magazine has stopped publishing. If it is true, a pity - use to feature some good local cars.
  7. 400 - not enough for a tune. And, you will have to run it on 98 all the time to take advantage of that tune. Plenty on the n/a section of the forum on this - as for cold air - hunt around for a second hand fpv type air snorkel that goes under the headlight as that will be more than enough air supply.
  8. There you go - the whole package. Get some good brake fluid and do a fluid change as well, a few drinks, tools and a lazy saturday arvo and just enjoy the work. For under $500 ( drinks and a feed included) fit the lot and smile.
  9. Brake pads - good info all over the forum..... However, be honest with yourself....... how fast are you going, where are you doing this and how many times? The stock brake pads are good for the occasional hard run. So, whatever brand you choose, try to equate them to what you are doing. If EBC red is one step up from the greens, then maybe look at those. If you can get the brackets etc, fit the 322's. They are ok and run a little cooler than the 298's. As for which rotor brand........ plenty of opinion on that. Have used both DBA and RDA.
  10. Nuthin wrong with a good four. Going bacvk a few years - I reckon my s15 ( withj mods) was a great road car albeit a bit small for taller people............. well, it was a great road car before she-who-must-be-obeyed pranged it.....
  11. On the b series they don't stay on at all.
  12. Grab your wallet, put on the nikes and run.
  13. There is a fair bit on the forum about cam changes. However, with nothing else, it is the usual thing - top end results with little in the midrange. I understand that HPT software does allow for some changes in the way the vct works however, adjusting that does not seem to produce any marked results.
  14. Well done. Yáll gotta be very happy with 345 at the tyres through stock mufflers - - - - I am beeting there is no drone, cabin roar, drumming harmonics at 95 - 100km/hr, pipes banging on the diff cradle or kids in the back seat with headaches. Good luck with the next steps.
  15. We assume the dump pipe was done. A good turbo side air box has shown gains ( see the work done by Ratter on this.) Other than maybe pushing more boost into it ( assuming the waste gate is the right size ) I reckon not much more that is really cost effective that will give you what you want. Sadly, power and dollars are a hyperbolic function........ with dollars climbing the fastest !
