TomT
    3
Everything posted by TomT
  1. Not sure why the air con module would be doing that to the cluster. Has the top of your strut broken off and gone through your ecu loom like Jeremy's Porsche in the latest Top Gear special?
  2. With Pandora you pick an artist that you like and it will play some songs from that artist and also a range of similar music to that artist. You then have the ability to thumbs up or down a song, if you thumbs up it will play music more similar to your taste and if you thumbs down it will never play that track again. Eventually it should be playing music based on your taste and you will find heaps of music you like that you never knew existed.
  3. ^ Doubt it if he's tried new cluster Maybe try checking and re-seating the plugs on the BEM - not sure where it is in the B series (I'm sure someone can chime in) , in the FG it's top left of the driver's footwell.
  4. But you will still be driving an xr6
  5. In saying that though, if they did have a 800hp rating it is still a good turbo. If you want 480-500 with a good spool (spools faster than GTX from most accounts so far) the 6466 is still a nice option. It is a bit of a PITA to fit though. Luckily I got mine cheap and that's what I want from the turbo. The guys who spent nearly $3k and were expecting the 600kw that was stated are understandably disappointed, which is what Veva is getting at.
  6. We need more info old farmer! Please obtain!
  7. Is there an issue with running a cooler thermostat? ie engine doesn't get to operating temp? I bought the project I'm working on at the moment and it has one installed because it was from Townsville. I live in Sydney West, should I throw a stock one back in or not worry?
  8. Tennis
  9. TomT
    In The Club
    Why is the bottom heat shield not there? Just decided to leave it off? How's that going? Absolute PITA putting that heat shield back on
  10. Gold
  11. Vacuum
  12. Hit IP limit again. 837.
  13. I was second owner, got it with 4000km odo, gearbox replaced at 9000km odo, not even questioned about obvious mods as it is a known fault caused by a factory item.
  14. Where's one of the forum's IT gurus to set up an automated voter? Haha
  15. Nice work Hamish! Traction feels pretty good too, doesn't it
  16. Can also vote, clear cookies/cache, vote again, repeat
  17. That's rubbish. Plenty of people have had the gearbox replaced under warranty due to milkshake. Mine was replaced under warranty at 9000km and I had all the normal mods and 300+ rwkw. It's a common issue. Definitely dispute it.
  18. Wow $40 entree must be a lot of prawns
  19. It's not the end of the world, take it easy if you're worried but a good tune should have enough tolerance for a different brand of 98. Just fill up with BP98 next time and forget it ever happened.
  20. I wonder if anyone has actually ever paid for the full version of winrar haha. I'm not complaining though, one of the first things you install on any new pc.
  21. Hoping to make a tad over 500, which it should sh*t in. Actuator is 14lb
  22. Yep have to swap the mechatronics unit. Only other way is swapping every module in car (ecu, bem, icc, cluster, igniton barrel etc) which obviously you won't want to do
  23. That's because you have a wheelspin tune Hamish. If you had a more progressive one and some good tyres it would be fine.
  24. Spythe, you 100% on that? Can anyone else confirm?
