masda74
Gold Donating Members
    17
Everything posted by masda74
  1. you didn't flash the valet tune into the car by accident did you?
  2. Cool, then that explains it. I was just worried it was rubbing somewhere.
  3. okay, hold on for a sec. Rewind..... I have no issues viewing the pics. Imgur not blocked. Those are snap on weights for the inside of the rims right..... ? The clip to the inside/lips of the rim. If the weight is rubbing on the rim, then something must be pushing the damn weight on the other side....... I have to be missing something here. do you have a pic of when it was installed?
  4. Sorry, I haven't been on for a while. I am catching up on the older stuff now. If the motor keeps winding all the way down, it sounds like you might have the wiring incorrect. Maybe swapped the pins during the transplant? Did you transplant the motor and loom @plonker04? Tagged you since you have't been on since the beginning of December. Hoping that by tagging you, it will email you a notification.
  5. Thanks K31th.
  6. I am to lazy to use the search function right now and I am sure that K31th knows this off by heart already. Who's the closest recommended tuna for him?
  7. far out guys. we have been rude. to our forum. You have come to the right place. Steer clear of pingune in regards to those email tunes. Cut your loses now, cause $240 isn't that bad. Had your engine blown, it could have been more expensive. Where are you located?
  8. Fark, I hope it is not Pingtune at it again. As mentioned above and in many other threads, do not load email tunes into the ecu. You are better off getting the car tuned at a respectable tuna in your area. there are threads on the forum with respectable tunas in your area.
  9. masda74
    P1131 code
    fair call. Well good luck with it then and hopefully it holds on.
  10. Steve, where was it rubbing on? the brake caliper or the spindle/control arm?
  11. nah mate, just I'm I <3 Bananasing with ya.
  12. masda74
    P1131 code
    did you get Mr bolt or Dr bolt out to have a look?
  13. too late. I bent the exhaust in the right spot so it doesn't have to get a dent by the axle. I got the same dent now. Thanks freaky.
  14. masda74
    P1131 code
    @hpfmnst, any update on this. did you get that bolt out after all?
  15. now you got me thinking. I need to check mine then. I know you have a ute and I have a sedan, but don't they both cross over in the same place?
  16. Dafaq is this? devil reincarnated in some form or another. What were they thinking ffs. @Ford Freak in the middle pic, is that your axle hitting the exhaust, cause I can see a dent in there?
  17. I see the OP was on yesterday. Is there an update to this? @mike0819, Did you manage to get it to a mechanic or the shop that tuned it?
  18. If you are worried about the u1900, don't be. If you leave the Bluetooth ODBII device plugged in and torque running when you start the car, you get that code. I normally make sure that torque is not on, when starting the car. Once the car is running, then start torque. I can't give you a definite answer in regards to the O2 sensors.
  19. Awesome work there. Very jelly on this side of the screen. Your PMs are turned off or your mailbox is full. Have you played much with the settings for the shockworks at the track? Previous owner of my coilovers mentioned that for normal street duties that 4 at the front and 3 at the rear would do well. However for track work, a firm 6 at the front and back would be best. Maybe give that a go?
  20. Monsta torque are in Malaga and know the falcons well.
  21. I think it may be to late to mention this, but I will in any case. Don't forget to get braided lines. that also makes a big difference when it comes to brakes. You don't get the spongy feel. that was the biggest thing I hated when I got the car.
  22. so have you got another car yet, or still deciding on the RS5???
  23. fair enough. have fun. I am not sure we have enough interest though. I might have to go and join CLUB FG or Mystic or what ever they are called...
  24. Toooo Late. Now my OCD has kicked in. I am going to have to get under the car and hang off that muffle to make it twist to one side........
  25. So any update, or did he do a runner? I have this feeling that tonight is gonna be a ....... now I got the stupid song stuck in ma head
