MR_FG_09
15 Good
About MR_FG_09
1,908 profile views
  1. Ok I dont have any glitches like that but one annoying thing sometimes maps isnt there I have to refresh the screen, but ive found if I start my journey on the phone first then connect it to the car its ok just gets annoying if you stop for fuel or any quick stops then have to reconnect, its not always the case though The microphone I just have tucked at the top of the steering column & dash I'll see if it'll let me upload a pic Sent from my SM-S901E using Tapatalk
  2. I have the Kayhan V6 MK2 upgrade in my FG MK1 I couldnt get the factory microphone to work so fitted Kayhans microphone it seems to work ok Sent from my SM-S901E using Tapatalk
  3. Im not sure what they are worth nowadays no doubt alot dearer like everything now but you can contact Ray at Western Suburbs Diffs in Brissy he has a Facebook page
  4. Hey mate no I didnt need the fronts rolled at all & your correct 6 Pot Brembos on the front with plenty of clearance
  5. Car: 2010 FG XR6T Trans: Monsta Torque stage 3 6R80 ZF 3200-3500 rpm stally, Under chassis mounted trans cooler with fan Power: 390rwkw on 98, 437rwkw on E85 Boost: 20 psi Induction: Process West 4" Race intake Intercooler: Process West stage 2 Turbo: Procharge ProGTX-62, 12psi actuator, 39mm flapper Engine: Valve Springs, Head Studs, Ross Racing balancer, Yella Terra flex plate dowelled to the crank Exhaust: Huricane 4" dump 3.5" cat back Fuel setup: Xpurt 1000cc injectors, Walbro 460Lph intank pump Driveline: G&J Drivelines Pro Shaft, DSS 800hp rated half shafts Suspension: Tein coilovers all round, superpro bushes through out, IMS twin bush hat Wheels/Tyres: 18x9.5 all round, 245-40 F&R Yokohama AD08R Semi Slicks Brakes: Brembo 6 pots Front, FPV Pbr upgraded rear all in Black Tuning software: SCT X4 Tuner: Profile Autosports Capped at 437rwkw with the single intank pump will go a surge, reg & rail next year & push for more power possibly some bigger injectors as well the car is my daily but I enjoy taking it out to QR for early morning roll racing events
  6. I started out wanting them the same as work wheels bronze but ended up custom mixing till we got the paint looking good & then ceramic coating once the paint had cured
  7. No problems mate that's what the forums are for just a FYI my rims arent the Rota bronze ive had mine custom painted to my desire Where did you order from?
  8. The +35 sits in slightly but comfortably takes a 275 with no scrubbing 500hp used to be my end figure but the goal posts have moved
  9. I run my 18x9.5 +18's all the time you may fit a 255 maybe a 265 the 245's do the job but at the track when its cold they struggle abit with 400rwkw It looks better with the same offset all round & gives you the ability to rotate the tyres for more even wear
  10. Yeah mate I actually have a 2nd pair of Rota Grids that are 9.5 +35 which I can use for track days & throw on some semis in a 275 or 285 but to run the 9.5 +18 I had to have the rear gaurds professionally rolled
  11. He took a few shots inside as well They poke a little but fly under the radar It wasn't a planned photo session my detailer was working in the workshop in the background & decided to take a few shots when he ran the car outside but 100% id have the tyres wiped clean for sure [emoji1690]
  12. I run 18x9.5 +18 all round with a 245-40-18 On Tein super street coilovers
  13. Sorry never got pics of the 700hp shafts as I was working while the car was having upgrades done but these are the best pics I got I gave Ray a hand to drop the diff then had to go so never seen the shafts or wavetrac before fitting
  14. Left outer cv And it was a 700hp rated shaft apparently someone over tightened it im not sure if that is a legitimate issue though or not
  15. that's good to know ive been running the 700hp rated shafts for the last 3 years daily driven & plenty of roll racing events But I haven broken 1 shaft back when the car had 324rwkw on the baby turbo
