Banjora07
2 Neutral
669 profile views
  1. No one come across this before blowing smoke only when slowing down always thought my car was a one off one off sh*tbox
  2. Yeah its just a guess with the values idk mechinc did it there telling me rebuild but if I can just do my head up and do bottom end next year would be good
  3. Hey guys just got my turbo rebuilt but still pumping out smoke on declaration been told it might be value steam seals but had a leak down test and got two cylinders are low its a bf typhoon all the usual mods just wondering if anyone had same problem thanks
  4. hey guys I have a 05 typhoon which on the last tune was told I have blow by I've done a compression test all fine 182 in 4 cylinders and 185 in 2 cylinders it has 120000 on the clock I know my turbo has had it but it blow the dip stick out while being tuned just wondering does a pcv valve wear out or should I go catch can thanks
  5. hey boys my turbo on my bf typhoon sh*t its self was wonder will a gtx3582r be a direct swap I have a 4 inch intake rear housing flaper mod done and 4 inch dump in know I need new silcone rubber frm turbo to pipe to turbo but anyfing else.thanks
  6. hey guys I thinking of getting the throttle body relocation kit for my 05 typhoon has anyone got one or knw any info I like the sound of losing 1m of intercooler piping and do I need to change pipe from intercooler its a rapid v3 to suit process west pipe of throttle body thanks boys
  7. when u do zf service do tranny cooler or new heat exchanger I got zf service 6 months later zf milkshake so yeah just my experience
  8. Would it be cheaper going for a c10 of going manual if its $3000 for that and $5000 for rebuild that's f*cked
  9. Do you know what it cost them for the mechatronics unit please
  10. I just got a milkshake but I not quite shore if my mechtronics unit is gone car still drives just had to turn it around I will be getting a rebuild next year but I have a budget of $6000 if the mechtronics unit is gone I don't know if I got enough for it all I wnt a built gearbox if any one had the same problem any info would be good thanks
  11. Is the computer any or is it f*cked Iam doing the rebuild next year engine light come on and said cylinder head is over heating done compression test ranged from 180 to 185 thanks guys
  12. Oil is normal colour I think oil has mix with coolant
  13. Hey guys my coolant milky as my partner drive it today it started over heating and find its or milky and it blew or over the engine bay (it got off ). Any way is it head gasket or a zf milkshake it's a zf 6 speed that is starting to slip it done 112000km with 338 rwkw it's a 05 bf typhoon. What's best brand for head gasket thanks
  14. Hi guys I was told my engine has a bit of engine blow by I Havnt done a compression test yet I pulled off the pcv hose of and it had oil on it. Is that normal can has done 112000 km and tuner said it was done to the car pinging from old tune should I be alarmed with the oil on the pcv hose thanks
  15. Ali tried to play with the settings of the box but this was the best outcome he could get so its time for a box rebuild as the old saying goes you get what you pay for
