My_XR6_Turbo
25 Excellent
3,467 profile views
  1. Real quick one guys, what are the 2x bolts that bolt the CAT to the dump pipe on a BF XR6T? Are they the same as the studs/nuts on the exhaust manifold? I need to purchase some more. Thanks in advance,
  2. Haven't tried jumping on them but yeah I have tried cleaning the sensors. I just printed the pinouts from the manual. I'll start probing on the weekend.
  3. Good afternoon guys, I have an 03 BA XR6 Turbo. The ABS light is on and when I scan for codes I get: Code: B1342 - ECU internal fault Module: Antilock braking system ECU internal fault. Has anyone had this fault before? Is it an ECU or ABS problem? Is there a way of telling without buying a new ABS module/pump? Thanks in advance,
  4. How about this? I also found this which explains the wiring. https://www.fordxr6turbo.com/forum/topic/73177-plazmaman-surge-tank-and-plenum-install/?tab=comments#comment-1080003
  5. I emailed them too about a month ago and they said get a professional to install it. I have one too that I'll be installing in the next month or so (I need to somehow get the fuel lines made). Any help/Photos would be great. Could you take a photo of the tank and label what goes where and also take a photo of the fuel lines and label those? Any help would be much appreciated. Could you also take a photo of where you hook up the relay/wires? 🤞 Thanks heaps!!!!!
  6. Car will be running 1000cc injectors, E85, bosch 044 external pump in a BF MKii. Thanks again.
  7. Hi guys, Can anyone tell me what each one of these connectors are called and sizes? I'll grab them from vpw once I know what they are. Big thanks!
  8. Pull the fuse for the fuel pump.
  9. Thanks guys. Best place to buy it?
  10. Hi guys. I've got a walbro 460 pump. Is there a direct swap adjustable reg? I've also see some adjustable generic regs with gauges built in for $100. Are they any good and will they fit a bf turbo or do I need to replace the fuel rail? I do like the $100 generic ones as they have the gauge.
  11. Hi guys, I'm installing a walbro 460 intank pump and I know I need to drill the return line out to 4.5mm. Is this the right one? Can anyone explain what the center one is for as it's blocked? Thanks,
  12. Wow I have never seen that before. As k31th said grind, cut, replace, weld, prime, paint. I wonder what caused it. What's the other side like? Have you looked under the doors for rust?
  13. Thanks for the reply. The car "seems" to run ok. If in park and I bring the revs up a bit you can hear it kinda pops if that makes sense. I'll try and get a video tonight. If I clear the code it will be ok for 2 weeks then just pop up. I think both sensors are on. When I did a log I saw this.
  14. Hi guys, I have a BF Mk II with Plazmaman 1000hp cooler, 3" cold side piping, battery relocation, flapper mod, 12 PSI actuator, 42Lbs injectors, 255l Fuel pump, 200 cat, center muffler delete and 2 new O2 sensors. I had the engine light come on and I get P0172 System too Rich Bank 1. I also get RXE and ROR codes. What causes rich and what is ROR and RXE? Many thanks in advance,
  15. Has anyone used any of these before? Looks more solid than the OEM. http://www.ebay.com.au/itm/POLYPRO-FORD-FALCON-BA-BF-REAR-DIFFERENTIAL-MOUNT-CENTRE-BUSH-02-08-BUSHING-/131827851125?hash=item1eb18d5f75:g:I40AAOSwepZXRpW7 http://www.ebay.com.au/itm/SUIT-FORD-FALCON-BA-BF-REAR-DIFFERENTIAL-MOUNT-CENTRE-BUSH-NOLATHANE-49187-/232174762699?hash=item360eb1bacb:g:SJ8AAOSwEzxYSI4P http://www.ebay.com.au/itm/SUPER-PRO-FORD-FALCON-SEDAN-BA-BF-DIFF-CENTER-REAR-SUPPORT-BUSH-KIT-SPF2654-70K-/222324482538?hash=item33c39261ea:g:XnoAAOSwa~BYNkbJ
