chrisxr6tute
3 Neutral
  1. you can get em on ebay to
  2. Had this exact problem in my 07 turbo ute oil change and now all good, used nulon and nulon LSD additive, might go penrite next time
  3. Hi lads and ladies I am hoping some one may know where I can source the large stainless steel wrap around hinge for the BF ute FOBAFCP28548A Or can anyone provide pics or specifications even a drawing of the said hinge so I can make one myself Any help or suggestions would be invaluable, even if you have one laying around or a wrecker may have that would be appreciated. Cheers
  4. I have a BFmk2 Turbo Ute and it had factory 322mm fronts, not sure about the rears, Just pop into any ford dealer and give em your vin they will tell you exactly what was fitted
  5. Hi guys and girls, I own a bfII lowndes Turbo ute, I am led to believ that by fitting Territory Rear calipers on the rear of the bf with a shim will allow you to fit ventalated rear disks. Has any tried this or know if it is possible. Also I know its the wrong spot, however, When I take off I have a small I wouldnt call it a clunk but more like a click from the front right and when I apply the brake to slow down I hear it again but a different level, its kinda like something is moving backward and forward slightly. Its an 07 with 78000 ks on the clock. Any ideas Thanks
  6. So u tightened it,I assume u can see both sides then, try fitting a rubber grommet in like a washer then retighten should stop it
  7. Factory option mine knocks in the rear even found the rear quarter panel not attached properly ,fixed that tightened everything had the diff rebuilt and anything else u can think of, still there's sometimes a knock even the fuel one someone mentioned. Found a solution that is easy and everyone can do. Turn up the tunes no more knock prob solved. BF TURBO UTE LOWNDES 07
  8. My XR6 Turbo Ute 2007 Lightning strike
  9. West of Melbourne XR6turbo ute lowndes edition no mods low kilometers
  10. Hi guys and girls I have owned a Craig lowndes BF MKII for about 2 years now its a lightning strike silver turbo ute with now 73500 clicks, I haven't had much time for clubs or such not ill now. My car is factory original meaning no mods at all except a towbar. I'm heading down to the all ford day at waurn ponds tommorow, was going to enter the ute but its just not clean enough and no time to do it, anyway I'm looking forward to learning new stuff here and seeing what others have done with their ford rides. Cheers
  11. Hi guys I have crossed to the darkside and traded my VY SS for a XR6 turbo ute 2007 By craig Lowndes picking it up Monday so Il post some pics then I have owned 2 fords previously a XB GS coupe with 302 and c4 top loader and a ef Futura. It has 40 thousand ks on the clock and as it came from factory with hard lid and what not Im sure ill have heaps of questions and stuff in the very near future, my brother should be happy being a ford man his entire life :sungum:
