Benfu86
5 Neutral
  • Interests
    cruising...
  1. Top video up Gary
  2. Great New Year cruise Gary!!
  3. 1 more week
  4. Only use united but 20L jerry can should do be enough
  5. That's a yes Gary Any e85 along the way?
  6. Minimum 19, I could be wrong
  7. Benfu86
    Next Vic Cruise
    +4 option 2
  8. Benfu86
    Next Vic Cruise
    ^^ sounds good to me
  9. Got a question to ask our knowledgeable forum members. Car is a BA MK2 XR6T, just recently; I have some problem with stalling, mind you; it only happen when the engine is warm up. Drove it a 10-15 mins, normal drive; car is stop; ignition off. After 10-15, car wouldn't start up normal; crank start, stall for 3-4 times. Waited for a couple of minutes, then start up fine. Check for codes, nothing. First I thought was e85, then run it on 98 does the same. My guess is tune, or it could be something mechanical. Any helps will be much appreciated. Cheers, Ben
  10. ^^^ http://www.rapidsystems.com.au/index.php?p=1_102
  11. Freaky, you will also need full exhaust system plus what Nic say to keep up with ET before going to Calder. cozetdoesn'twait
  12. ^^ when's the next run ET vs Freaky?
  13. Benfu86
    Next Vic Cruise
    xmas week cruise would be great
  14. How much fuel when you surge? Coil usually you can tell by mis fire or one cylinder down.
  15. what is the usual labour price for fitting?
