As in the map sensor near the head light under the battery that's plugged in. The boost solenoid is that under the battery near the turbo? How did you fix the earth problem? If all that is plugged in?
Hi I have a bk mkII turbo ute that has the following error codes p0243 and p0238. One the ute I have an aftermarket intercooler and a plazaman off the turbo. I have changed the sensor under the battery and its been at ford with no luck. Is there something I can do or try to fix it, or does any one know some one I can take it to who is good at fixing these codes regards stephen
Just check the old rubber is off I put in penrite HPR 5 5w-40,and notice a slght leak near the new oil filter how do I stop the leak or fix it? Its a repco filter, I had put some old oil on the seal and its done up hand tight
Hi all, I changed my oil in my bfgf mkII ute on the weekend, since then on cold start tge oil light comes on for a second or so . What could be the problem, over fill or a leak?
