Azid
Everything posted by Azid
  1. not 100% sure so dont quote me but from memory when I pulled mine out when stripping I looked at new one and it looked like there would be enough room to fit it behind the sub as the sub sits in the middle and the small break light fits into the angle of windscreen, like bionic said id get the parts needed its a lot easier to work things out when your looking at them. Alternatively you could just pick up a thin red LED bar and mount it somehow in the back parcel shelf or top of back window
  2. Go to wrecker and find one if the factory parcel shelf brake lights n wire it in its only the vehicles with premo sound that came without it from what I believe
  3. That's what I was thinking if it was Ecu then would b error code not no power. Havnt been able to check anythin between long shifts and sh*tty weather will b making an effort tomorrow arvo I'll check fuses I know kickpanel connectors are good
  4. yeah no worries ICC has been looked after and handled carefully s id be surprised if something was wrong with that. Could it be a computer issue? Im pretty positive the 2 same sized ecu plugs are in the right spot so shouldnt be an issue but not sure if ecu could cause it?
  5. Righto buddy makes sense I've taken ICC out fair few times over the years and had no issues must have been lucky cheers man
  6. Righto man cheers I'll give that a try when it stops raining hopefully it's a simple fix like that and not a deeper problem with wiring or computer
  7. What do u mean research it? The ICC has been out I put it back in yesterday it felt like it pushed back into the plug cleanly and the 4 plugs at bottom are in properly
  8. Hey guys I've rebuilt my car from ground up in new shell used same wiring looms and everything completely same stuff as came out of my other one when came time to power it up I got dash lights etc but no ICC power up. Any suggestions what could cause this? No offense to anyone but just people who actually have experience I don't want to hear things people have read and speak out about such as needs reprogramming from ford etc Cheers guys
  9. Azid
    Fuse Box
    oh come on its only 4 bolts haha nah that's cool man cheers for that much appreciated hopefully turning car over tomorrow first time since september
  10. Azid
    Fuse Box
    Cheers man is there a certain way back plugs go or do they only fit in one spot?
  11. Azid
    Fuse Box
    im pretty sure ive worked out the 5 plugs in the back of the fuse box, hopefully there in the right spots but ive got one loom with a brown plug on the end and it has yellow plastic around wiring loom and it comes from the engine bay fuse box into drivers side kick panel any ideas where this plugs in?
  12. Yeah I had this a while ago the light would come on during heavy breaking definitely a break issue it turned out to be my rotors
  13. Hey guys just seeing if someone could post a pic or help out with the 5 plugs that go into the back of the interior fuse box. I took them all out thinking they only fit in one spot a while ago and then when I went to plug them in today Im not sure which ones are meant for where as some fit in a few spots, plus ive got 5 spots and 6 plugs so not sure which is the odd one out, any help or pics would be greatly appreciated cheers
  14. No tune Can u use another type of sensor or does it need to be factory?
  15. Factory ones or can you just get a brand aftermarket one?
  16. The sensor was broken in an accident and car is stock
  17. Azid
    Wire Positions
    Righto cheers mate appreciate it
  18. Azid
    Wire Positions
    That bolt for the earth near the abs that's where it bolts to the chassis isnt it? Where on engine does the other end bolt to? Cheers on starter I'll run it along crossmember
  19. Hey guys Just enquiring about the boost sensor that's on the Ubp I need a new one and fraud want $181. Can anyone suggest sonewhere cheaper I could get one or is there an alternative to the factory one? Cheers
  20. Hey guys Just seeing if anyone could tell me and/or post a picture of where the short engine earth bolts onto the engine on drivers side? It's bolted to chassis just down from fuse box and goes to where? Also could someone tell or show me best place to run the starter motor to battery power cable so it isn't near hot things Cheers
  21. Where are bayswater at? So they do 4 spd rebuilds to handle 400rwkw for less than 3k?
  22. So you don't need the squeezed tight o clips you can just use the good quality screw tight clamps to join the fuel lines to hoses and hoses to engine? I assumed it had fair mount of pressure that's why they used the O clips
  23. And what r they lIke?
  24. http://www.fordxr6turbo.com/forum/topic/44426-premium-sound-icc-and-dvd-head-unit-install/
  25. hey guys anyone had anything to do with these guys or heard anything? It seems really cheap which makes you a bit suss http://www.ebay.com.au/itm/XR6-Turbo-Automatic-Transmission-rated-400rwkw-/251110064219?pt=AU_Car_Parts_Accessories&hash=item3a7753805b#ht_500wt_1321
