Poonman
About Poonman
  • Birthday 10/10/1976
  1. But I can’t do this all the time do you know the reason for this happening ? How to fix it .
  2. Just purchased a 2006 turbo Territory and every time I plant the foot down the ABS traction control and park brake lights come on and the car looses power and the speedo stops working any ideas guys ?
  3. Happy Birthday Poonman!
  4. Happy Birthday Poonman!
  5. Thanks guys for all your feed back ill look into all the options, to run e85 been told that it will rust my exhaust and have to drain tank to run 98 again is this true or if its nearly empty you can just top it up from there and change tune thanks Poonman
  6. Hi I have just hit 388.3rwkw I have a Ba mkii F6 Typhoon it has a 31/2 inch C.E.S. exhaust, 3.2 Process West kit ,Fuel pump and 60lb injectors and turbo modified Autotech tune very happy but want more so any tips would be great thanks Poonman
  7. Hi just wondering if anyone has any info about airbag light that comes on then some days it stays off been told its the plug on the front seats can anyone give me any advice on how to fix this problem cheers for any help kimbo
  8. Happy Birthday Poonman!
  9. I have a BA Typhoon Build number 496
  10. I have a turbo back 3 1/2 inch ces exhaust and no tune and as I am still driving it, it is over boosting but I have got a lot more to come and don't want to pay for tunes after each mod it drives fine just don't give it a hard time till you tune it but uses a lot of fuel
  11. Can anyone one suggest a good tuner in sydney I've heard about intune at seven hills are they any good
  12. Thanks for your input guys ill look into it can anyone suggest a Heavy duty clutch to use
  13. Hi guys can anyone give any advise on adjusting my clutch as its at the end of the peddle the car has 90000kms on it and there not hard kms am I up for a new clutch thanks kimbo
  14. Happy Birthday Poonman!
  15. Thanks heaps for your input I'm in Sydney and I don't think it's a shake it's like the wheels are spinning but not it doesn't happen all the time it's like the diff is moving from side to side I have lacked it up and put on stands to see if there is any movement but none I'm puzzled
