sixman
    6
sixman last won the day on February 25
sixman had the most liked content!
194 Excellent
About sixman
  • Birthday 20/11/1975
    Hills District, NSW
  1. I got some made 10yrs ago from a shop in qld. Cant remember the name now doh But they maintained the seat based side airbags with proper double stitching etc.
  2. Throw in a "cooler". That will bring back memories
  3. If its a street car, gtx3576 is more than enough. On the street you will notice lag more than an xtra 30-50kw. Besides, above 350kw you will start breaking other things, and find things you need to upgrade to keep up.
  4. Looks better than new! Paint was fading on mine, ended up wrapping it, was quite a bit cheaper than respraying, but wont last anywhere near as long.
  5. Nice one! Been running a 9174 for years on my street manual. Using a small 0.83 iwg housing, get crazy boost early, better than the gtx3576 I had 10 yrs ago. Getting 20psi by 2750rpm lol. I have a built engine so can handle back pressure. Obviously top end limited but still get 450rwkw, enough for the street and fast spool is hilarious.
  6. More for wet weather and emergency braking on front. Front end grip is superb, will oversteer before understeer. Rears can grip in dry 450rwkw manual on the straight, but only when warm. I do have upgraded driveline and diff though. R888R is a bit better on rear for dry straight line grip, but for a predominantly street car is way too noisy.
  7. I got same staggered wheel setup in 18s. PS4 on front, Cup 2 on rear.
  8. Looks like Joe has left PR. Anyone know the goss? Must be end of the road for Falcon tuning/mods soon
  9. Look for Ford headliner replacement. Lots of guys can do it, there are mobile ones that will come to you. Cost is circa $400
  10. Is your current cradle cracked/brocken? IM twin bush diff hat if your rebuilding it.
  11. The mk1 screen is better as it is bigger/brighter and doesnt lean back as much - so less reflections. I use this in my mk2. I vaguely remember seeing a post about a new even bigger 4k screen.
  12. How could this happen? The rag was in the intake pipe? How come it only went into the turbine wheel after 6 months? Shrapnel through the engine is disastrous.
  13. I have been using Kayhan unit for several years. If you have installed a car audio system or dash cams its very easy to fit and wire up. But its not quite plug n play, and I think that is what has caught people out. The V1 unit had problems, but the newer versions are fine. I have had no issues for years. They now have a cheaper unit that runs on linux rather than android. Good option if you use carplay or android auto. I think they have a bigger 4k screen as well. I still daily my car half the time, it brings the infotainment upto modern newer cars. I even run draggy on it lol
  14. I think they have a much cheaper linux based unit now. Makes more sense if using andoid auto or carplay as you dont need access to apps in the headunit anyway.
  15. sixman
    VARi brake kits
    Clearly he has a very small hand!
