bionicxr6t05
Bronze Donating Members
    3
Everything posted by bionicxr6t05
  1. I have two 1400s on order, one for mine and another for an r32 rb25 im building to run e85 around 450hp
  2. No impellor is right, all used cars have a mandatory statutory warranty period, driveability concerns are covered
  3. Yeah try throttle clean tighten both manifolds then discinnect battery for 10 min
  4. that's a great method
  5. Its brown.... Ish
  6. Remove rear wheels Back off cable from underneth the car until the handbrake levers sit on the backing plate Remove rubber grommet in disc Turn starwheel through the hole anti clockwise turning disc with a screwdriver occasionally until very light contact is made between the shoes and disc, you will hear it rub when you turn it. DO NOT OVERTIGHTEN. You only want a small amount of contact. The levers should only be able to come off the backing plates 5-8mm. Next tighten the cable until there is no slack between the cable ends and handbrake levers. Refit wheels. Should hold at 5 clicks and come up a maximum of 7 clicks
  7. Actually to correctly fill a zf the fluid temp must not go above 38 degrees However im sure that spec was given for the lifeguard fluid so not sure what the go is with aftermarket fluids
  8. Well said tab, the term "if your not doing anything wrong youl be fine" is now obsolete as its not upto a court whether your car gets crushed its upto the officer and how his day has been.
  9. Battery is flat
  10. Haha cheers, the external gate setup itself has gains but wether or not the screamer is vented or plumbed in makes no difference
  11. Yep
  12. Lolits boostcruising did u expect anything less?
  13. Actually the fix for pc also works on safari for ios, so can view new content using safari!
  14. I use my phone 99% of the time... Looks like il be on here a lot less
  15. If o2s heater circuit is a hard fault (code wont clear) check all fuses and test o2s heater (two black? Wires on upstream o2sensor) for open circuit, may be stuffed upstream sensor. Ensure no vacuum leaks and manifolds are tight.
  16. Mine is earthed straight to the boot floor with a bolt and nut, engine bay earth is zip tied to main fusebox wiring harness
  17. I experience both stock and modified fg xrts almost every day.... Still rather the gtx
  18. Same here no topics in "all topics" or "unread" tapatalk 1 latest version only started 2 weeks ago, very annoying Also its only on this forum too, have a couple other ones I go on and they are fine
  19. Disconnect the battery with the ignition on
  20. No will be fine
  21. And truck drivers winge about other road users!! How does check ya mirrors sound!!! At least your ok mate
  22. Have to get ford to do everything I said above
  23. Just because your underpowered limo still hooks up in the wet
  24. 2jz
