bionicxr6t05
Bronze Donating Members
    3
bionicxr6t05 last won the day on November 9 2012
bionicxr6t05 had the most liked content!
709 Excellent
1 Follower
About bionicxr6t05
  1. Hi, I'm a new member so forgive me if I'm not following protocol but I noticed one of your posts where you said you can replace diff bushes (I have a G6ET) for under $500 and that you were in Sth Brissy. I would love to get it done if you had the time. Or even a number I could get ya on to chat about it. Thanks heaps!!
  2. To access contacts on a samsung you need to import all contacts from the sim card to your phone memory as the bt system will not read any sim contacts... iphone5s are crap (as with all apple products) for bluetooth compatibility as they do not provide any third party with their specific bluetooth protocols or coding.
  3. Does your mate realise you can use the pcm part number to program a blank pcm?
  4. fits aftermarket bushes under warranty... even if the customer pays for the parts
  5. If a dealer does that they are idiots... so many reprocussions for them... but that's their problem lol... iv had a bf f6 sedan tramp badly before all stock... set tyre pressures to factory... all fixed, other than that never had a customer complain of tramp in 8 years so I wouldnt think its a common enough issue for ford to warrant or even acknowledge.
  6. No they will not fit aftermarket bushes under warranty.
  7. The iphone bluetooth stability issues are to.do with the phones design itself. The problem is the wifi antena is right next to the bluetooth antena and it causes interference if wifi is switched on. Switching the wifi off will help with bluetooth stability but will not entirely prevent iphones dropping out. All manufacturers have this issue as apple is not very friendly with sharing software etc. The bpm (bluetooth phone module) is vin coded to the acm (audio control module), fdim (front display interface module) and aim (audio interface module), therefor all 4 modules MUST contain the same vin number for the systems to work, hence the need to program the new module
  8. Il be rude... your mechanic is wrong and stupid lol
  9. Sounds like timings out or cam caps are not in their correct positions
  10. There is a factory recall... some utes were fitted with lower rated springs than they should have
  11. If you have an fpv its internal in the bem. If you dont have an fpv you dont have a factory alarm
  12. You could try... some would say wear and tear. I probably wouldnt do it under warranty unless there was a material defect
  13. Not 100% sure mate, oils have evolved and this 5w30 that's upto the latest spec is very high quality... just about every new ford uses it from diesels to lpi falcons to transit vans
