Super Nes
  1. Yeh I bought mine as a whole unit from ebay, plenty of sellers there.
  2. yeh mate easy as. didnt need the walkthrough at the end of it.. a little tedious but all good ta
  3. About to change mine, did mine in the BA and found it a little tricky at times. Is there a walkthrough or guide for doing it in the BF to save me some time? Guessing it's really similar to a BA
  4. Any group buys on Blue Power Cold Air Intakes?? I will be buying one very soon
  5. in case anyone checks this later, it's all done
  6. Impedance is 4 ohms Thanks mate
  7. From the amplifier manual if this helps.
  8. Hi guys, I have a Pioneer GM-D9500F. It's a 4 channel amp, with the ability to switch to a 2 channel. All I want the amp to power is 1x 12" Sub. In the second image, how are my connections to be made? Do I bridge anything out? Power, ground and system control are fine.. it's more to do with just the Sub Connection. Ta
  9. Thanks for the reply mate, have any good tutorials to run by? I figure im just going to run new cables to the amp and treat it as a normal install, leaving the old cables safe but redudant. Deck is the only tricky thing so far with mention of high-low converters etc?
  10. Hi guys, been reading for a while now and finally decided to ask the experts. The setup so far; BF MkII with premium sound. Is it possible to replace the stock sub and amp with my own provided Pioneer setup? Is it as simple in regards to running no new cable? Essentially, I would like to have my own deck installed in the tissue box holder and have that linked with the new sub/amp (stock speakers). Is that possible to just remove what is currently there and have all required wiring there? Or will I need to send away part of my stock setup to have RCA outputs installed? Thanks in advance.
